Thread: boxford tip
    hi my name denis
    i have 2 boxford tcl 240
    I would like to remove the spindle and put a classic drill bit for and a cylindrical piece to work with a bridle.
    i took pictures. someone made this change?
    when the old owner bought it they tried to do something, but it is incomplete. see attached photos.
    know that it tapers and deltro the (sleeve) the tube to be able to put a support to put a tip.Click image for larger version.
ID:	29863Click image for larger version.
ID:	29864Click image for larger version.
ID:	29865Click image for larger version.
ID:	29866Click image for larger version.
    Lives in East Lothian, United Kingdom. Last Activity: 9 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,911. Received thanks 360 times, giving thanks to others 8 times.
    That looks like it's got a camlock spindle fitted.
    Given there's only 3 mounting holes, it'll either be a D1-3 or D1-4 - https://www.smalltools.com/lathe-spi...ication-chart/
    It looks like the previous owner has fitted some form of manual collet chuck.
    Once you've identified the spindle fitted, googling should find suitable chucks.
    It is likely that the spindle has a Morse taper in the bore. I have a D1-3 nose on my Colchester Bantam and this has a MT5 taper. If yours does have a Morse taper, you can buy a collet chuck eg ER32 or ER40. You will need a drawbar too but that should be simple to make.
    These are widely available on ebay, Amazon and AliExpress
    https://www.aliexpress.com/item/32908168694.html
    thanks. I also thought that inside it is in a large morse cone,
    I will check with a bore gauge to be able to measure inside
    I have 2 same lathe, I try to check in the first lathe
  1. FOR SALE: Boxford MT2 & Boxford TCL125
    By jonnydeen in forum Items For Sale
    Last Post: 12-11-2021, 11:24 AM
  2. Boxford 260 VMC
    By shoeswith in forum Boxford Vertical Mills
    Last Post: 10-04-2017, 06:20 PM
  3. Replies: 2
    Last Post: 21-04-2016, 09:18 AM
  4. Boxford 165 HMC
    By uli12us in forum Boxford Vertical Mills
    Last Post: 24-01-2016, 08:21 PM
  5. Boxford mt2
    By Hellfire in forum Boxford Lathes
    Last Post: 03-08-2012, 08:46 AM
