Thanks jazz, read page 5 of the link you provided, same as the link I provided from the Russian site to back off the analogy i first posted. My first post clearly started the info from the different card and was what I had to hand at the time.
My recommendation remains, try it as is, the provided driver software hard codes the output mapping
09-07-2021 #2
That's my point it's just a standard BOB, not a motion controller like the NVEM so the MOTOR OUTPUTS will need to be set up. Not having a pop just wondered how you thought it was a NVEM or motion controller.?
A note for REGPYE: You will also need to apply 12-24V for the inputs and outputs to work, it basically power the optos. See Diagram on page 2, just above the inputs you have 12-24v connectors.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
Please help - missing steps ... Mach3
By emilvv in forum Artsoft Mach (3 & 4)Replies: 21Last Post: 23-12-2019, 08:31 AM -
New Mach3 settings but limit switches do not work, using a JK02 breakout board help!
By JimK in forum Artsoft Mach (3 & 4)Replies: 1Last Post: 27-09-2019, 11:54 PM -
switches settings in mach3
By Palletlad in forum General DiscussionReplies: 2Last Post: 17-09-2019, 05:40 PM -
Mach3 turn screen missing items / incomplete?
By mondrota in forum Artsoft Mach (3 & 4)Replies: 7Last Post: 27-02-2018, 06:30 PM -
Help withController dip switch settings and Mach3 motor tuning
By liamo1991 in forum Motor Drivers & ControllersReplies: 2Last Post: 15-11-2013, 02:22 AM
