21-08-2020 #1
I have some slots/holes (typically 2....3mm wide) to do pretty accurately in a number of pieces of 80% nickel sheet, so the CNC's the obvious go-to. I was told by the supplier that it's a bastard to work with, does anyone have any experience of this please? I'm guessing it will be a bit like stainless & work harden rapidly hence you need to press on mercilessly, but if anyone has any info on speed & feed I'd be very grateful, thanks.
02-11-2022 #2
Hi, i work with nickel alloys on a daily basis.
Yes it will work harden rapid with that specific grade. That grade can often cut like aluminium, and clog up 4 flute cutters.
We tend to mill much larger than 3mm. However we have found 2 flutes work well. As for feeds & speeds, i would aim for a slightly higher feed than you would for stainless.
As you mention you need to press on merciless with it.
I find carbide or HSS tools work well.
The Following User Says Thank You to TheHybridOne For This Useful Post:
03-11-2022 #3
Cheers for the advice - I'll try some 2 flutes next time I have to do some parts.
600LBs cast iron monster !!
By VulcanMachineCo in forum Manufacturer NewsReplies: 2Last Post: 30-01-2019, 07:05 AM -
RFQ: Marking a cast iron
By mike stat in forum Projects, Jobs & RequestsReplies: 1Last Post: 13-09-2012, 10:22 PM -
RFQ: Small parts CNC machined from iron
By luc in forum Projects, Jobs & RequestsReplies: 1Last Post: 20-06-2012, 09:24 PM -
What is the best sheet alloy for machining?
By p1lts in forum Metalwork DiscussionReplies: 2Last Post: 09-10-2011, 11:37 AM -
Temperature Controlled Soldering Iron
By M250cnc in forum General ElectronicsReplies: 9Last Post: 17-01-2011, 02:01 PM
