18-04-2022 #1
Hi All,
I moved to New Zealand 5 years ago. My belongings inc my CNC router only arrived recently . Now I'm set up again but totally out of practice and forgot a lot that I need to teach myself again. I was no expert to begin with but Ok for being self taught.
I run Mach3 .Version R3.043.062 I have an issue I remember having last time I used it that I need to sort before I start again. Maybe simple ?.
In the middle of milling product, if I notice something is not quite right with the toolpath or I need to pause the program momentarily, I use FeedHold. As I understand it, after I want to continue the process I press Cycle start again. But then something disastrous happens and the spindle moves or jumps to a different part of the nc file and the tool crashes into the vice or other part of the product . Un-related to where it was left off. Maybe I have a setting in Mach3 ticked or un-ticked that is causing this?
Also another small issue was my nc file and mach3 had conflicting Safe Z points. What is the simplest way to keep this a standard ? Keep the Safe Z dictated in Mach3 or in the .nc file ?Last edited by dudz; 18-04-2022 at 04:14 AM.
NCStudio to Mach3 question for a chinese 3020 router
By Fivetide in forum Chinese MachinesReplies: 3Last Post: 11-04-2015, 10:37 PM -
How would you fasten back to back carriages?
By CharlieRam in forum Rails, Guideways & BearingsReplies: 10Last Post: 04-09-2014, 11:01 PM -
angular contact bearings - back to back, further apart
By dsc in forum Linear & Rotary MotionReplies: 16Last Post: 05-01-2014, 10:59 PM -
Mach3 Easy Question For The Experienced
By Carlb1058 in forum Artsoft Mach (3 & 4)Replies: 9Last Post: 08-04-2013, 09:48 AM -
5 Years in! here goes my build
By cncezee in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 03-03-2010, 11:49 PM
