    ian's Avatar
    Lives in London, United Kingdom. Last Activity: 16-07-2022 Has been a member for 2-3 years. Has a total post count of 25.
    Hi All
    I'm in search of a fly cutter or another type surface mill / shell mill to fit an ER20 collet and 2.2kw spindle. It is for surfacing hard engineering plastics, aluminium and maybe the odd occasional soft steel.
    I've seen some on ebay and some generic ones, but ideally want to buy a decent tool for a decent price. Can anyone recommend a good fly cutter or shell type mill, preferably from a UK supplier?
    If your spindle is the typical 2.2kw water-cooled spindle then you won't have enough torque at the low rpm's that a wide fly cutter or large shell mill requires. What diameter were you thinking about.?
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
    ian's Avatar
    Hi Dean
    It's the typical 2.2kw HY spindle. Mostly I have to face 600mm x 600mm hard plastics and occasionally smaller aluminium parts. I was hoping I could get a 35mm (or at least a 25mm tool) as I thought that would be the maximum size and load for the spindle.
    Quote Originally Posted by ian View Post
    Hi Dean
    Ok well, the 50mm version of this is what we use for surfacing with the 2.2Kw spindle and have used for HDPE and Aluminium on occasion and the finish it leaves is fantastic. I've run low as 5000 rpm upto 10,000rpm
    It may seem pricey but long term it's cheap as you get 4 sides per blade and the blades are cheap. Well worth the money IMO.
    https://www.wealdentool.com/acatalog..._Wing_928.html
  6. #5
    Lives in Plymouth, United Kingdom. Last Activity: 6 Hours Ago Has been a member for 9-10 years. Has a total post count of 1,729. Received thanks 295 times, giving thanks to others 11 times.
    I use a 50mm carbide-tipped cutter in my HY spindle. I would say that I get away with it rather than it's ideal. Runs at 7K, which is about as slow as my spindle will run and still give any torque. Only used for surfacing a spoil board and with no more than 0.5mm depth in ply or mdf. That was a cheap eBay buy, but it's ok for the job.
  7. #6
    Have a look at scott and seargent, the CMT surfacing bits are pretty similar to the Wealdon but a good bit cheaper, same replacable blades, they have quite a lot of decent endmills and stuff.
    https://www.scosarg.com/search-resul...name=match_and
    Ollie
  8. The Following User Says Thank You to Ollie78 For This Useful Post:
  9. #7
    Quote Originally Posted by Ollie78 View Post
    Ollie
    Cheers Ollie, at those prices I will give them ago, I've got/used a big 2-1/2" yellow jobby to good success in MDF, just a cheap (£15) one off Amazon but a CMT will be a nice upgrade.
    .Me
  10. #8
    ian's Avatar
    thnx Dean / Ollie
  1. 3kw Chinese Spindle - ER20 denford triac question
    By andy_con in forum Denford Mills
    Last Post: 03-11-2015, 10:14 PM
  2. help me buy an er20 collet for my lathe/mill
    By kingcreaky in forum Workshop & Equipment
    Last Post: 13-11-2014, 03:03 AM
  3. The tips of my 20 mill cutter get loose ...
    By hoezap in forum Tool & Tooling Technology
    Last Post: 06-07-2013, 11:55 AM
  4. FOR SALE: ER20 DIY Spindle Parts
    By Mad Professor in forum Items For Sale
    Last Post: 03-11-2012, 06:51 PM
  5. Conversion of ER16 spindle to ER20
    Last Post: 14-07-2012, 05:19 PM
