21-07-2022 #11
Here is a picture of the lathe:
Its an 8 position ATC driven by a Yako YKA2404MA stepper motor driver.
https://www.yakotec.com/index.php/proview-21-15.html
ATC Schematic:
21-07-2022 #12
If you remove the stepper motor from the ATC, does it spin unloaded? I'm asking because Sieg seemed to be suggesting you should play with the driver settings. Didn't work but can you get ANY life out of the motor when it is free to spin? Failing that, would it be worth spending a few quid on a generic Chinesium stepper driver to see if the Yako thing really is the problem? Changing out the CNC controller itself is a big move, so you'd want to be 100% certain the driver and motor are OK first.
The Following User Says Thank You to Muzzer For This Useful Post:
21-07-2022 #13
Hi Muzzer,
You make a good point and I started thinking back through after my last post this afternoon whether I really had ruled out other issues before going with SIEGs suggestion of replacing the motion controller and considered trying another stepper motor driver.
I will do some more investigating as you say (and I had done some more tests this afternoon too. e.g. I ran several hundred lines of code with tool changes removed to see if the motion controller threw any problems and all was fine.)
First I will remove the stepper motor and try spinning it unloaded and work back from there. Updates to follow.
21-07-2022 #14
Current Activity: Viewing Wiring plan for upgrading my chinese cnc electrics enclosure, have I missed anything?
If there is only one stepper in the ATC then you might just switch to using a UC100 and Mach3/4
21-07-2022 #15
I'd also go with Muzzers suggestion first.
The chances of the controller physically failing are pretty slim, but given it's a pretty unknown controller, it's hard to make suggestions.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
22-07-2022 #16
Quick update:
I took the ATC cover off ready to remove the stepper so I can try it unloaded and there are no mechanical issues as I can rotate the ATC by hand by rotating the shaft with the machine/steppers powered off.
22-07-2022 #17
22-07-2022 #18
So things seem to be mechanically OK.
Next easy test, can you rotate the stepper motor with the lathe powered up?
This will tell us if the stepper driver is doing anything.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
22-07-2022 #19
The stepper motor driver and stepper motor are definitely doing something as they can partially rotate the tool but stop after about 30 degrees at which point the lathe hangs and disconnects from the PC running the turning software.
When I get some time this weekend I was going to remove the stepper motor from the ATC to see if it can complete full rotations without load.
22-07-2022 #20
That does sound far more like a controller issue.
Do you have any kind of manual for the controller?
How do you home the Turret?Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
Sieg mini lathe cnc conversion need help
By diddly in forum Sieg LathesReplies: 0Last Post: 20-12-2014, 10:53 AM -
Chester MF42B Lathe Wiring Issues
By kingcreaky in forum General ElectronicsReplies: 5Last Post: 18-02-2013, 02:21 PM -
FOR SALE: Sieg C3 Mini Lathe
By Jonathan in forum Items For SaleReplies: 1Last Post: 07-05-2011, 06:19 PM -
WANTED: SIEG C3 Mini Lathe
By derekm in forum Items WantedReplies: 5Last Post: 07-04-2010, 08:35 PM -
WANTED: SIEG C3 Mini Lathe WANTED
By derekm in forum Items WantedReplies: 0Last Post: 03-08-2009, 03:02 PM
