    cncroger's Avatar
    Location unknown. cncroger Last Activity: Has a total post count of n/a. Referred 6140 members to the community.
    :?: :?: colchester student 1800 squarehead lathe :!: :!:
    Help Help Help
    I have had the(luck) i am not so sure now, to aquire the above lathe for only £200.00.
    Unfortunatly person or persons had robbed it for spares, :cry: somthing i did not know when i bought it :x ......albeit from a scrap dealer, still what is left is in dam fine nick, and well worth renovating.
    one of the items taken are the change gears, now i am quite capable of cutting these gears if i knew what the original blank diameters were. is there any one out there who could either provide this information or could measure the root dimention of there change gears, so i can make a start at cutting gears :|
    Info/at/foundry-foparsdotcodotuk written in this form to reduce spammers
    Roger
    Hiya, i have moved your post to these forums, you should get a better response this way !
    .Me
    cncroger's Avatar
    Thanks for moving post, :D
    Roger
    Sorry, dont have a student, but from memory some colchesters have the gear data on the inside cover.
    i will check out the 'odd job' lathe and see if i can find any data for you
  1. New toy: Setting up Colchester Student lathe
    By Jonathan in forum Milling Machines, Builds & Conversions
    Last Post: 09-04-2015, 04:17 PM
  2. Colchester Chipmaster Lathe HELP !!!
    By snookaman in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 28-08-2013, 10:23 AM
  3. WANTED: Head Tram Square
    By dudz in forum Items Wanted
    Last Post: 31-03-2013, 01:03 PM
  4. colchester student 1800 help with knowin what my lathe is capable of
    By whensparksfly in forum Milling Machines, Builds & Conversions
    Last Post: 26-01-2012, 03:30 PM
  5. colchester student 1800 help with knowin what my lathe is capable of
    Last Post: 26-01-2012, 01:26 PM
