Thread: Need a pulley
    Aluminium Pulley for a 1.8kw servo.
    Ribbed J type belt, 8 section.
    19mm bore with keyway.
    112mm outer diameter.
    Clamp type collar not grub screw.
    The only one I could find off the shelf is a Dunlop taper lock type but is cast iron, so it's fairly heavy.
    Lives in East Lothian, United Kingdom. Last Activity: 10 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,911. Received thanks 360 times, giving thanks to others 8 times.
    I'm guessing given you're looking for an 8J pulley, this is for a spindle?
    In that case, I personally wouldn't worry about the extra weight of cast iron. It won't make that much difference to a spindle in the grand scheme of things.
    Yes.
    Servo spindle.
    Thanks for clarity.
    I was unsure about it stopping it quickly under an e-stop condition.
    It's actually a J4 belt, was asking for J8 pulley in case I update the Spindle itself at later date.
    112mm od gives me upto 5600rpm at the tool.
    What about Fenner taperlock pulleys?
  1. Custom Pulley Help - ATC over hall
    By andy_con in forum Denford Mills
    Last Post: 08-02-2016, 04:02 PM
  2. Cutting HTD pulley(s)
    By Jonathan in forum Metalwork Project Showcase
    Last Post: 11-12-2012, 07:19 PM
  3. pulley ratios on 3 pulley axis
    By Swarfing in forum Belt Drive, Pulleys & Timing
    Last Post: 21-07-2011, 12:43 AM
  4. Pulley kit to step up a stepper RPM
    By HankMcSpank in forum Belt Drive, Pulleys & Timing
    Last Post: 11-07-2009, 09:49 PM
  5. WANTED: Timing Pulley Suppliers?
    By m_c in forum Items Wanted
    Last Post: 02-11-2008, 01:02 AM
