Thread: Stationary Ball Screw
Yes its been done before and it works well.. and the downsides are:
1/ the motor driving the ballnut is on the moving assembly so adds to the weight needed to be moved
2/ the ballnut has to be driven via a timing belt or similar arrangement which just makes things more complex...Last edited by Lee Roberts; 28-12-2009 at 01:28 AM. Reason: Spelling der !!!
28-12-2009 #2
While it will work, it actually adds a lot of cost to it.
As mentioned you have a larger mass to move due to mtor motor moving with the nut, you also have to design the gear mechanism with a timing belt and pulleys and mounting for the motor.
When you could just buy a thicker crew with a larger lead, or use rack.Visit Us: www.automationshop.co.uk
Advice on new table and ball screw.
By D-man in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 26-07-2012, 10:45 PM -
Ball screw
By luke11cnc in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 20-10-2011, 01:28 PM -
Ball screw mounting questions
By Redccm in forum Lead Screws, Nuts & SupportsReplies: 3Last Post: 28-01-2011, 09:29 PM -
WANTED: 12mm ball screw & nut
By phill05 in forum Items WantedReplies: 8Last Post: 22-06-2010, 09:26 PM -
Ball Screw Accuracy V Price
By Wobblybootie in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 02-01-2010, 11:55 AM
