23-01-2023 #1
As luck would have it, my Windows XP PC blew up. I managed to source a Windows 7 PC with a parallel port, install mach3 and transfer over my config XML and license from an old backup. Doing this seems to have transferred over the pin settings etc, but I can't get any movement out of the motors. The DRO is changing like the machine is moving when I use the arrow keys, but the motors aren't working and the spindle won't start up with the usual command either.
I'm using a Marchant Dice (I know) machine with a Tonman Superbox control box. The box's red e-stop LED won't turn off either, which is probably telling of some kind of issue, but I'm stumped after scratching my head over this for the better part of 8 hours.
24-01-2023 #2
Is the new PC 32 or 64bit?
The parallel port driver won't work on 64bit.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
24-01-2023 #3
24-01-2023 #4
The estop light on the control box does go off momentarily during PC startup, and I managed to get it to go off by pressing movement keys in a particular order while mach3 was open but I haven't managed to replicate this. The CNC did not move, however.
24-01-2023 #5
It could be the parallel port is set to the wrong mode in the BIOS, but it's that long since I've had anything to do with a PP, I can't remember any of the details.
There should be guides on the Mach site, or in the forum.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
24-01-2023 #6
24-01-2023 #7
26-01-2023 #8
I'm having zero luck with this.
I've flicked through all the modes for the PP in the bios and tried each
The port address is definitely correct, the mach3 drivertest tool runs fine. I've gone through several threads and the fix is always something to do with the port address.
I've attached some screenshots of my stuff
26-01-2023 #9
Did you manage to work out the wiring for the machine?
Have you got any photos of what BOB (Breakout Board) is fitted?
My suspicion is it's possibly a chargepump config issue.
The chargepump needs to receive a fixed frequency signal from the parallel port, otherwise it won't allow any of the outputs from the BOB to enable. It's a safety feature to avoid any 'random' movement/activations caused by uncontrolled parallel port outputs, which can happen as the PC hardware gets configured as the PC boots.
However, the fact the E-Stop light goes off during booting, may mean it's using a simple enable output.
Some photos of the inside of the control box would be helpful.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
27-01-2023 #10
There are currently 17 users browsing this thread. (0 members and 17 guests)
help moving mach3
By kell in forum General DiscussionReplies: 1Last Post: 07-05-2021, 03:38 PM -
moving from Mach3 to AXBB
By ngwagwa in forum CNCdrive (UC100, UC300ETH)Replies: 5Last Post: 12-04-2020, 10:01 AM -
Windows 7 ~ Microsoft relents on shorter Windows 7 support decree
By AndyGuid in forum Computer SoftwareReplies: 4Last Post: 15-08-2016, 03:30 PM -
problem unzipping a file Windows XP
By mekanik in forum General ComputingReplies: 6Last Post: 08-01-2015, 10:32 AM -
moving mach3 help please
By h4ppy-chris in forum Artsoft Mach (3 & 4)Replies: 12Last Post: 07-03-2011, 07:33 PM
