Thread: atc spindle
    hi , i have just mounted a new atc spindle to my router which is running fine , my issue is the setup of the manual tool change button ,i have two solenoids in line ,is it possible with the use of a relay to disable one when the spindle is running and the other working from the button ,and if so how do i set it up? i am running uccnc withe the uc300eth-5lpt and ucbb
    the spibdle is a 6kw hqd
    Lee Roberts's Avatar
    Lives in Wigan, United Kingdom. Current Activity: Viewing Moderator Control Panel Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,914. Received thanks 227 times, giving thanks to others 776 times. Made a monetary donation to the upkeep of the community. Referred 11 members to the community.
    Hi did you get anywhere with this?
    .Me
    hi lee , today i got the solenoids sorted i used the trigger output function of uccnc to control the solenoids the way i want them , i have 2 in line one is controlled by the button on the spindle the other is connected to an output through a relay and is disabled when the spindle starts using the trigger output function " i have been informed that i could have connected the solenoid to the output without the use of a relay as the breakout board outputs 24v, " the third solenoid i have setup to be active while the spindle is running , for the air seal , hopefully i have got it correct time will tell. i now have to tidy up the wiring in the cabinet and tram the spindle and get back up and running.
  1. Replies: 16
    Last Post: 06-05-2023, 11:44 PM
  2. Chinese 300W DC spindle - is the spindle shaft grounded?
  3. Replies: 5
    Last Post: 29-09-2014, 02:42 PM
  4. Replies: 0
    Last Post: 13-11-2013, 07:50 PM
  5. DIY Spindle - What type of bearings are best suited for a spindle.
    By 8iggles in forum Spindles & Drive Motors
    Last Post: 09-02-2011, 10:15 PM
