07-02-2010 #16
Hi Hank
How much of a rush are you in, I'm sure I could make you batch of 10 or 20 next weekend. Ive just drawn the 240mm radius over 55mm width and its only 2mm. So with the band saw I can cut the rectangular blanks and then I'm thinking that with a radius jig mounted on the bench grinder the raduis can be ground, which would also give a nice finish as this will be the visible bit.
Milling mild steel
By dudz in forum Machine DiscussionReplies: 33Last Post: 16-02-2014, 02:31 PM -
RFQ: Several mild steel parts
By dudz in forum Projects, Jobs & RequestsReplies: 6Last Post: 26-08-2013, 11:37 AM -
How do I get this widget made (a small rectangular bit of 1.6mm mild steel)
By HankMcSpank in forum Marketplace DiscussionReplies: 25Last Post: 03-05-2013, 09:31 AM -
Cutting 1.6mm mild steel with a CNC machine?
By HankMcSpank in forum Machine DiscussionReplies: 4Last Post: 01-05-2012, 09:56 PM -
Homemade desktop CNC - cutting 0.8mm mild steel out the question?
By HankMcSpank in forum General DiscussionReplies: 7Last Post: 16-04-2010, 09:37 AM
