Thread: Bipolar motor voltage
23-02-2010 #1
I recently got some bipolars from a forum member, they are 23HS8404's by Motion King, in the spec sheet on their website, there is no listing for the voltage of these motors, can anyone help with this ?
Wildbill
24-02-2010 #2
thats because the voltage of the motor is fairly irrelevant for a bipolar motor. Its the current that matters and assuming you have a constant current driver (e.g. either a chopper or PWM) that is the key value. The other key parameter is inductance of the windings as this tells you how the motor torque will roll off at speed and therefore the ideal driver voltage, which is 32 x sqrt(inductance in mH). so a 3mH motor ideally would like a 32 * 1.732 = 55v driver. Of course a lower voltage will work but wont get the same torque at the higher speeds.
If you want to know more just ask...
24-02-2010 #3
Bill
First hit on google says
23HS8404 Double stack, 76mm, 6mm, 1.8, 40vdc/4.2amp/2 phase, 180N.cmIf the nagging gets really bad......Get a bigger shed:naughty:
24-02-2010 #4
Irv you clicked [enter] at the same time
24-02-2010 #5
Thats the breakdown voltage of the windings, not the operating voltage. A more useful spec is http://www.alibaba.com/product-gs/28...ze_57mm_1.html which shows these are 4.2A 0.6ohm motors (nominal coil volts 2.52v) and 1.8mH so ideal driver is 42v, they should work good on a 36v driver.
24-02-2010 #6
the is what was on http://www.rhonmac-cnc.co.uk/electronic_hardware.htm. shame they never explain?
24-02-2010 #7
Thanks for that, the motors are double stack, 76mm long and are (i think) based on nema23's the motion king website states that the current rating is 4.2 amps, i dont know if thats per winding (per phase ?). Can you recommend suitable drivers for these ? I have already started building the table and gantry with bearings made from alli angle and skatebord bearings, i would like to get these motors turning and download some software, just to get thing moving along (no pun intended). lots to think about. Thanks for your help.
Wildbill.
24-02-2010 #8
While im on, derlin nuts ? ballscrews ? backlash? , it would be very helpful if there were a place on the forum for a glossary of terms and explanations of what these and other related thing were, to help newbs like myself. I know there is loads of info here, but that would be great if it was all in one place.
24-02-2010 #9
Well a good starting point might be the tutorial I wrote here on choosing stepper motors...
A glossary is a good idea... let me think on it... but for a simple explanation:
most CNC machines use some form of screw mechanism to convert rotary motors to linear motion. The motor turns the screw and a nut riding on the screw transfers the power to the linearly moving part. Screws are generally made of carbon steel. To maximise power transmission they have special thread forms, usually trapezoidal or square (Acme). Minimising friction is critical, so the nuts are made of bronze or of hard but machinable engineering plastics like delrin. Typically the energy transmission of such an arrangement is 30% because of the frictional losses. Nuts are not perfect, if there was a 100% fit the friction would be very high, so there is a point where the screw turns but the slop between the thread of the screw and that in the nut means the nut doesnt move.. it is tiny but measurable. This is backlash and its one of the high goals of engineering to minimise it but still make the screw turn freely. Ballscrews use a different thread form and the nut comprises a number of ball bearings that run round the screw thread and recirculte back through a tube. Because the balls rotate and therefore have low friction they can be a much closer/tighter fit than a conventional nut, meaning reduced backlash (not zero as some claim) and higher efficiency (80%). Ballscrews are the screw of choice but the cost is 20 - 50x a standard screw.
24-02-2010 #10
The Following User Says Thank You to irving2008 For This Useful Post:
THE Bipolar Stepper Driver. Have you seen it?
By NorDevX in forum Manufacturer NewsReplies: 19Last Post: 23-09-2013, 08:45 PM -
voltage on motor wires
By phill05 in forum General ElectronicsReplies: 9Last Post: 11-02-2012, 03:43 PM -
Alternator low voltage
By M250cnc in forum General ElectronicsReplies: 12Last Post: 24-02-2011, 11:23 AM -
A brushless DC motor with no back EMF - E-Orbo current/voltage traces.
By machinevolt in forum General ElectronicsReplies: 8Last Post: 06-02-2010, 10:15 AM -
UniPolar vs BiPolar
By Lee Roberts in forum Stepper & Servo MotorsReplies: 0Last Post: 19-10-2008, 01:17 AM
