    Hi all,
    The time has come to retire mk1 cnc router and build a better one! Mk1 used mainly wood for the frame and gantry, and had too much flex. Photo of mk1 attached, which is now dismantled.
    Attached is a render of the mk2 machine. Spec is as follows:
    system3 all in one board
    33v power supply
    3Nm steppers on X and Y
    1.8Nm stepper on Z
    ball screws all axes, dia 16mm with 5mm pitch
    X axis ball bearings running on base frame, with adjustable side preload
    Y axis rail and carraige (20mm)
    Z axis rail and carraige (15mm)
    1.5Kw water cooled spindle motor (Chinese)
    1.5Kw VFD from Moeller
    Photos show the mk2 progress on the base frame, gantry, and Z axis. Tomorrow the ball screws are being machined to fit into angular contact bearings
    The aluminium side pieces need to be replaced with longer ones because during the build I decided to move the side rails out to make the gantry bearing system work better. Another job to do !
    Photo of my spindle and VFD unit, to replace noisy router, including mains filter and 200W braking resistor. I intend to use a ThermalTake 850i water cooling unit (for PC CPUs), as I've seen this used elsewhere for this application.
ID:	2219   Click image for larger version.
ID:	2220   Click image for larger version.
Name:	Copy of IMAG1231.JPG
ID:	2221   Click image for larger version.
Name:	Copy of VFD.JPG
  1. Boxford 190vmc upgrade
    By GeoffV in forum Boxford Vertical Mills
    Last Post: 13-06-2018, 07:46 PM
  2. Kress Spindle upgrade to a 2kw
    By Metal pecker in forum Kress Milling Motors
    Last Post: 05-05-2014, 12:22 PM
  3. Improve Kress TIR or get an upgrade?
    By Hauk in forum Kress Milling Motors
    Last Post: 23-02-2014, 06:18 PM
  4. Upgrade? Chinese CNC Machine
    By Carlb1058 in forum Machine Discussion
    Last Post: 15-08-2013, 09:04 AM
  5. Upgrade
    By Dopy in forum General Discussion
    Last Post: 09-11-2011, 01:57 AM
