Thread: 11" Harrison
21-06-2010 #1
I need a feed shaft for my 11" Harrison 40" between centres. The one that drives the auto longitudenal feed. The lathe has a Norton type gearbox. Has anyone any suggestions where I might buy one?
21-06-2010 #2
Isn't it just a straight rod with a keyway in it ?
John S -
24-06-2010 #3
hi Hobnob
As far as I know yes it is a straight shaft with keyway but as mine has either been broken and removed or at some time simply removed I have no idea what it should look like at each end nor do I know what diameter it should be. What are your thoughts? If I had an engineering drawing of one I guess I could have one made but without that I need some one to tell me where to obtain either a new or used one. Many thanks for the reply
John R
24-06-2010 #4
Try emailing Tony at lathes.co.uk or try http://www.gandmtools.co.uk/makerspages/harrison.html
26-06-2010 #5
I have alreaqdy contacted the obvious sources with no luck hence the request for help
Thanks anyway Irving2008
John R
28-06-2010 #6
Hi
Have you tried these fellows, they claim to hold all the drawings?
http://www.600uk.com/products/machine.asp?id=142
TomSherline lathe, Chester DB11V lathe, Myford/ Rodney mill, CNC mill Isel/ home made, Sealy Hack Saw, Meddings Pillar drill.
My CNC converted Harrison M250
By M250cnc in forum Conversion Build LogsReplies: 6Last Post: 14-01-2022, 09:20 PM -
CONVERSION: Harrison Mill Conversion
By m_c in forum Conversion Build LogsReplies: 18Last Post: 27-10-2016, 07:15 PM -
"Hacking" and "Modding"
"Racks" VS "ball screw"
By C.AlveSilva in forum Linear & Rotary MotionReplies: 1Last Post: 17-04-2012, 11:53 PM -
Harrison M250
By Arthur Kingdon in forum Milling Machines, Builds & ConversionsReplies: 24Last Post: 14-06-2010, 08:36 PM
