Thread: The illusive Boxford 260vmc
11-08-2010 #171
Well ive stated my reasons for wanting one and to be fair MACH does have the facility, However as i said mach says spindle go at 3000rpm, but there is no way of you knowing if the motor has obeyed this command, this could be a too higher feed rate lowering the spindle rpm, i just thought it would be nice for me to be able to see if the spindle was doing as it was told and maybe in the future incorperating a feature that lowered the feed rate to keep the rpm of the spindle at its desired speed, that is why i wanted feed rate control as well....
I WILL BE WATCHING, BE ASSURED OF THAT lolAlways bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
11-08-2010 #172Always bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
11-08-2010 #173
Cheers George, the way i see it, even if i dont use the design it may be very usefull to other members should they wish to investigate the tacho question...thats what forums are about.. for a group of people to pool thair resources and help each other out to achieve similar goals and have a bit of a laugh and share friendships and experiences along the way.......so thats why i say "Im In!!"
RickAlways bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
11-08-2010 #174
12-08-2010 #175
12-08-2010 #176
lol.....a machine with flashing lights is illumination, nothing more.:surprised:
You see the point i'm making is, when i press cycle start and walk away i don't care how many lights are flashing, or tacho's are counting.:sad:
The machine is working, and the sweet music i hear, is metal being removed.lol
CNC does not mean "cuddle not cut":twisted:
12-08-2010 #177
12-08-2010 #178....a machine with flashing lights is illumination, nothing more.:surprised:
12-08-2010 #179
Twang!!!! squeel!!! screach!!! i2i runs back to the machine, the expensive part in the machine has a big gouge out of it....Oh no...lol.
.....Somewhere else in the world Rick notices that the spindle is not spinning as fast as it should be, a quick glance at the g-code shows mach is trying to cut too much material in the first pass, on closer examination the cutter is lower in the holder than it should be, it wouldnt have mattered much anyhow as the little enhancement passes the spindle speed back to mach and this alters the cut rate so when he walked away the expensive part would have been safe.
CNC also does not mean "computerised not controllable"
However i can see this debate and its anacronims going on for some time..
so I just say "que sera sera"
Rick..Always bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
12-08-2010 #180
Hey look at my avatar. lol Just for you i2i...
The Boxford 260VMC as you probably never seen it before!
By rnr107 in forum Boxford Vertical MillsReplies: 36Last Post: 28-04-2021, 07:57 AM -
Boxford 260 VMC
By shoeswith in forum Boxford Vertical MillsReplies: 3Last Post: 10-04-2017, 06:20 PM -
boxford vmc 300
By bigred5765 in forum Boxford Vertical MillsReplies: 0Last Post: 22-04-2014, 04:22 PM -
Boxford mt2
By Hellfire in forum Boxford LathesReplies: 6Last Post: 03-08-2012, 08:46 AM -
Boxford 160 TCL
By Brinner in forum Boxford LathesReplies: 1Last Post: 31-03-2012, 09:11 PM
