Thread: The illusive Boxford 260vmc
12-08-2010 #181
lovely avatar, does it control your keyboard.:heehee:
While i'm away from the machine everything cuts perfectly because it's computer numerically controlled. Mach3 does exactly what i tell it to do everytime i want it to, that's the trick when it's programmed.
But heaven forbid something would fail, as it makes no difference whether you have a tacho, a button for every controllable action and a light to show everything, you wont be there to do anything about it, unless of course you sit there and watch.:confused:
The only usefull thing on the front panel is the E-STOP
12-08-2010 #182
Hey C'mon that is a cool avatar!! i made that just to make you smile lol..
12-08-2010 #183
it did make me smile.
12-08-2010 #184Always bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
12-08-2010 #185
On a more serious note i2i, do you know what sort of temperature are these SD3 drivers heatsinks supposed to sit at when not doing anything??
12-08-2010 #186
they do run fairly hot, you should be able to touch the heatsink. If you're worried you could put a fan in there, some boxfords have a fan as standard.
Just think you could have a temperature controlled fan with a tacho and an led that gets brighter the faster the fan goes, and a digital thermometer for each drive. It'll be like christmas at Blackpool.
PS. i prefer the e-stop at the top.
12-08-2010 #187
Its funny you should say that, here is a little gadget i got to controll the speed of my dc fans related to ambient enclosure temperature... based on the input from some carefully placed sensors.
I put the E-Stop at the bottom so you could use your hip to activate if your hands were out of action. lol:rofl:Always bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
12-08-2010 #188
Well i've recieved quite a lot of bits today so i will begin the sensor tomorrow but i will hold on in completing the tacho circuit in the hope that someone comes up with a closed loop design....and.....que irving lol
http://www.mycncuk.com/forums/showth...counter-thread...
dum tee dum tee dum....
RickAlways bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
13-08-2010 #189
Hey,Rick
Unit here for £22...thatll do nicely for my lathe sir. :dance:
http://medw.co.uk/wiki/index.php?page=Tachometer
13-08-2010 #190
The Boxford 260VMC as you probably never seen it before!
By rnr107 in forum Boxford Vertical MillsReplies: 36Last Post: 28-04-2021, 07:57 AM -
Boxford 260 VMC
By shoeswith in forum Boxford Vertical MillsReplies: 3Last Post: 10-04-2017, 06:20 PM -
boxford vmc 300
By bigred5765 in forum Boxford Vertical MillsReplies: 0Last Post: 22-04-2014, 04:22 PM -
Boxford mt2
By Hellfire in forum Boxford LathesReplies: 6Last Post: 03-08-2012, 08:46 AM -
Boxford 160 TCL
By Brinner in forum Boxford LathesReplies: 1Last Post: 31-03-2012, 09:11 PM
