Page 11 of 14 FirstFirst ... 910111213 ... LastLast
  1. #101
    i2i's Avatar
    and drilling must be done in forward
  2. #102
    lol so i need to get it going both ways.
    Still a little confused where the wiring from no/nc/c should go on the contactor :(
  3. #103
    i2i's Avatar
    there are 2 contactors together, one turns the spindle forward and the other spins it in reverse. If i remember correctly the feeds for each contactor are on the right hand side about half way down.
  4. #104
    i2i's Avatar
    the no/c/nc is basically a toggle switch
  5. #105
    i2i's Avatar
    it switches the c to the no when you turn it on and back to the nc when you turn it off.
  6. #106
    Lives in East Lothian, United Kingdom. Last Activity: 8 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,910. Received thanks 360 times, giving thanks to others 8 times.
    What do you need to know about the contactor?
    Looking at the wiring diagram, it's an interlocking contactor, which means only one set of contacts can be active at any given time. They're typically used for motor reversing, as if both were to activate at the same time, the power supply (in your case the Gemini drive) would be short circuited, leading to fuses blowing/magic smoke being released.
  7. #107
    ah right i get it now,
    at this time im still confused how i should be wiring this up....
    Also would i be right in saying i would need two spindle boards for each direction?
  8. #108
    sorry if im being stupid, my brain is fried from this at the mo
  9. #109
    If you need both directions, then all you need to safely control the spindle, is another way of switching the power (a relay is the easiest option) going to the spindle board relay (C terminal).
    Connect the FWD contactor coil (after it's passed through the rev part of the contactor) to the NO terminal on the spindle board, and the Rev coil to the NC terminal (again after it's passed through the fwd part of the contactor). Then you have the other relay switching the power to the C terminal on the spindle board.
    That way the direction signal to the Spindle board controls the direction (it switches the relay on the spindle board), the step signal provides the 0-10V analogue out to control the speed via the Gemini, and the extra relay switches everything on and off.
  10. #110
    right so i have it all wired up now, i took the time to trace everything from the wiring diagram and from your help i think i have it..
    Now i just need to work out how to toggle the Step and Dir on the Spindle board to control the speed and direction :D
    I cant seem to get either Mach3 or EMC2 to work
  1. Can't reply to a thread
    By Washout in forum General Discussion
    Last Post: 24-10-2012, 06:56 PM
  2. Thread Engagement
    By GTJim in forum General Discussion
    Last Post: 12-09-2012, 11:13 AM
  3. Thread Tapping?
    By Tenson in forum Tool & Tooling Technology
    Last Post: 04-05-2012, 04:51 PM
  4. Thread diameter
    By Daniel in forum General Discussion
    Last Post: 23-02-2012, 06:18 PM
  5. Pipe thread in 22 tpi???
    By Robin Hewitt in forum Machine Discussion
    Last Post: 21-09-2010, 11:19 AM
