25-07-2016 #751
Great stuff Neil - bet that felt like a big milestone reached.
Will be nice to see how it runs in its new configuration.
ChrisMy CNC Projects: https://www.youtube.com/imadethisoncnc
25-07-2016 #752
You and me both Clive. Will be interesting when I fire t up again tomorrow. Need to make some rubber bump stops asap to park the gantry at the bottom safely...think I have some polyurethane rod somewhere.
25-07-2016 #753
How about those round rubber door stops with a hole in the middle? https://www.google.co.uk/search?q=ru...HcJvCbMQsAQITg
26-07-2016 #755
26-07-2016 #756
Control box & VFD on the wall....
now working on the electrics.... got the correct tool out....
Neil Do you think you will need another bracket to bolt the frame to the wall at the top, shimmed as to not twist the frame Hope you are only using he hammer to tap the connections into place
26-07-2016 #758
There are 2 additional bolts half way up bolting the frame to the wall...shimmed with custom cut bits of pipe 😁 the base is shimmed and bolted at all 4 corners so I'm hoping it's still all square....will tell when I first go to cut later today...
Hammer was, as you suggested, to tap in the wires...who needs screwdrivers?
26-07-2016 #759
Quick video....
https://youtu.be/F7W9s0fFaG4
Don't seem to be able to see any chips though . Just thinking aloud how about a brake operated with a solenoid that operates when you lose power. It could be on a counter weight steel cable over the top (on a pulley) and then brake the cable.
BUILD LOG: A3 Router Build
