Page 53 of 82 FirstFirst ... 343515253545563 ... LastLast
  1. #521
    At first glance I thought that, but he's using such excessively thick wire that it's probably not a big deal.
    It's wire I had left over from making Y leads for my large electric RC Helis, I though it would be good to use as I could strip sections of outer off, push it over the pin and then flood with solder. Then cover the soldered bit with hot glue to insulate....
    Neil...
    Build log...here
  2. #522
    Lee Roberts's Avatar
    Lives in Wigan, United Kingdom. Current Activity: Viewing Moderator Control Panel Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,915. Received thanks 227 times, giving thanks to others 775 times. Made a monetary donation to the upkeep of the community. Referred 11 members to the community.
    Missed that first time round, nice idea looks cool.
    Not sure on Clive and the chocblock, I guess he's right but what to do...
    I guess you need somthing of a busbar, mini consumer unit? Or is that ott?
    .Me
    .Me
  3. #523
    .Me
  4. #524
    Maybe mount the MCB's on the din rail with a busbar and then a seperate din mounted busbar for the -ve?
    Neil...
    Build log...here
  5. #525
    :) sounds like a plan :), just seen these: http://m.ebay.co.uk/itm/321061386290
    .Me
  6. #526
    I remember now...EddyCurrent linked to that in his build...looks like a good solution, ta!
    Neil...
    Build log...here
  7. #527
  8. #528
    Lives in Marple Stockport, United Kingdom. Last Activity: 13 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 3,333. Received thanks 618 times, giving thanks to others 78 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    These seem ok and you would get the fuses for the drives (if you want them) you would need two of them fuse in the +ve and bridge the -ve solid (no fuse) cheapo choc blocks will melt if the screws come loose. Clive
    ps the others with the led in would be no good as you will be running 70V ish.
  9. #529
    Yea i think the white version are the better ones, somthing about not melting.
    .Me
  10. #530
    How about soldering the 1 wire from the caps directly to 3 smaller wires and connecting them to din terminals.
    Then connecting from there to MCB's before going to the drivers?
    Neil...
    Build log...here
  4. BUILD LOG: A3 Router Build
