Thread: Center Drill Bits
Hi, i have recently recived some center drill bits as recomended by another member, i know what they are and how to use them.
I was just wondering if anyone had any advice or Tip when using them, i have been using them to make nema 23 motor mounts for my cnc machine:
22-06-2008 #2
Sorry kip i hit the wrong button, kips posts are below:
Be careful when using small ones on hardened steel...they break!
And use a scriber rather than a marker pen as it's better for accuracy and never rely on a piece of metal being "square" when marking out.... :D
22-06-2008 #3
Yes it did take me a few go's to get the holes right, i managed to get the holes close enuff that i could then file out a small amount so my screws would line up with the motors.
Now i have a template i just use that to make/mark out new plates and so on:
23-06-2008 #4
You really need CNC it makes it so easy and everything lines up just perfect. No more swapping centre drill then bit then countersink/bore on every hole :D
I draw everything with AutoCad, convert the milling to G code and overlay the .dxf file on the cut file. Then I can use the "Move to hole" feature which puts me on the hole nearest the mouse.
14-05-2009 #5
14-05-2009 #6
14-05-2009 #7
Forget centre drills, they are a throwback to earlier days and were designed for putting in the support holes for centres on lathes, hence the name.
No commercial CNC shop would dream of using centre drills today, instead using what are called NC spotting drills.
These are very stiff short fluted drills that will start a hole off without wander and not break like the flimsy centre drills.
Nearly the same results can be obtained using a good quality stub drill.
John S.
23-06-2008 #8
There are some really naff centre drills around, regular PITA when they snap off. I got some cheap, centred 2 holes then lobbed the lot straight in the bin.
Caveat emptor, I've gone back to Plan A, don't use anything but Dormer :D
23-06-2008 #9
07-04-2010 #10
Dormer aren't what they used to be...I picked up a set of drills, made in Mexico of all places. Drilled a hole in a piece of 1/4" mild steel and managed to snap a brand new 10mm drill bit straight in half with just the torque from a cordless drill and in a hand tightened QR chuck too!
That's the first time I've ever managed to break a drill over about 4mm in diameter!
Complete carp!
End mills / Drill bits for aluminium
By ivars211 in forum Tool & Tooling TechnologyReplies: 7Last Post: 10-04-2014, 08:01 PM -
Step drill bits (where to get) ?
By Gytis in forum Marketplace DiscussionReplies: 10Last Post: 07-08-2013, 12:04 AM -
FOR SALE: dormer jobber A100 drill bits
By Web Goblin in forum Items For SaleReplies: 1Last Post: 19-03-2012, 12:39 PM -
best drill bits
By oadamo in forum Tool & Tooling TechnologyReplies: 4Last Post: 01-01-2011, 11:25 PM -
Split Point Drill Bits
By Lee Roberts in forum Tool & Tooling TechnologyReplies: 0Last Post: 10-07-2008, 02:06 AM
