  1. Hi All
    I am looking at buying a Harrison Trainer 280 CNC lathe to learn how to program and to do a few small jobs. Dose anyone know if they have any common faults and can they be programed with a PC.
    MArk
    cees's Avatar
    Location unknown. Last Activity: 18-08-2011 Has been a member for 9-10 years. Has a total post count of 1.
    See my site www.leeuwinga.nl
    Lot,s of stuff about Harrison T280
    Of course it is all in Dutch but you can use Google to translate
    it into English.
    Harrison can be succesfull be controlled by a PC.
    Turnmaster Pro from Microkinetics is most suitable
    However some of my customers used Mach3
    The old computercard (BBC128K) need to be removed
    as well the two index cards, screen and keybord panel.
    On most of the lathes the drives are OK, so you can tap
    direct to the existing drives.
    The whole will upgarde your lathe to a full cnc lathe
    The only disadvantage on Harrison T280 is the fact that there are
    trapezium screws on Z and Z axle for a good CNC application
    you should change this to ball bearing scrwes.
  3. Hi
    Thanks for the help. I am going to look at your site.
    Mark
  1. My CNC converted Harrison M250
    By M250cnc in forum Conversion Build Logs
    Last Post: 14-01-2022, 09:20 PM
  2. CONVERSION: Harrison Mill Conversion
    By m_c in forum Conversion Build Logs
    Last Post: 27-10-2016, 07:15 PM
  3. CNC style lathe home brew Lathe for drilling and cutting.
    By Bodge in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 18-04-2012, 10:45 AM
  4. WANTED: 11" Harrison
    By Alfaman20 in forum Items Wanted
    Last Post: 28-06-2010, 11:46 PM
  5. Harrison M250
    By Arthur Kingdon in forum Milling Machines, Builds & Conversions
    Last Post: 14-06-2010, 08:36 PM
