    I had a notion that if I fitted cheap Chinese digital-scales to my mill I could stop worrying about backlash, stalled steppers, losing my zero etc. I could fit an automatic tool height detector and that positioning pendant I have always wanted, maybe leave it open ended so I could add other input devices I haven't thought of yet.
    I now have a little computer board which the PC can talk to. It reads 3 digital scales, drives 3 stepper motors, has a serial port to talk to the digi phase converter. Also SSR relay outputs to switch the suds and the main motor, plus 3 auxilliary ports for plugging in additional doo-dads.
    I've got the scales reading, haven't done their end sensors yet but that should be easy. Now working on the stepper control algorythm which sits on a timer interrupt...
    Anyone still with me? Or am I the only one who does this kind of stuff? :D
    Current plan is that each axis has two main variables, 'Where we are' WWA and 'Where we want to be' WTB. When the timer interrupt fires it does one axis out of 3. It compares WWA to WTB and if necessary steps in the appropriate direction.
    May seems complicated for a stepper algorythm, until you remember that WWA can change at any moment should the digital scale for that axis chime in with a new absolute position. I have the scales hard wired for speed, a complete 24 bit location received interrupts the CPU and gets read as 3 pre-digested bytes.
    On the last axis interrupt it does a more exhaustive test for position. If any axis is outside tolerance I don't update WTB for the next position so it does remedial steps until tolerance is satisfied. I think I have to allow a tolerance or it will get stuck. The screw resolution is .005 mm/step. The scale resolution is .00496mm, close enough that I can let the motors get a bit ahead of the scales. The scales report about 50 times a second, I usually do 300 steps/second so there has to be some leeway. If I can cut the tolerance to 3-4 steps I will be well within 1 thou accuracy.
    Quite enough for now. Did anyone read this far?
  1. Digital angle gauge
    By njhussey in forum Tool & Tooling Technology
    Last Post: 04-12-2012, 08:07 PM
  2. FOR SALE: DRO + 4 Scales
    By Rikk in forum Items For Sale
    Last Post: 22-10-2011, 09:41 AM
  3. Digital drivers from Zap
    By Simon C in forum Motor Drivers & Controllers
    Last Post: 31-03-2011, 03:27 PM
  4. FOR SALE: digital vernier.
    By i2i in forum Items For Sale
    Last Post: 13-08-2010, 11:31 AM
  5. Reading and fixing Chinese scales
    By irving2008 in forum Tool & Tooling Technology
    Last Post: 24-02-2010, 10:35 PM
