  1. #21
    Quote Originally Posted by swood1 View Post
    Are you talking about the green board?
    If so the connections on the right read look to read 10v, 5 (i assume volt), 0v, -10v. For some reason the machine was originally wired up using only the 5v and 0v connections. The bottom two wires are black/red for 240v ac. The Lenze seems to have a seperate 240v supply.
    Yes the green board.
    It's not unusual for some speed controlers to use 0-5V and the Pmdx 107 has this feature if required. However It's more common to use 0-10V.
    The Lenze controller can obviously use either.
    Agnd on pmdx 107 goes to 0v and Aout to 10V. By default the 107 outputs 0-10v so If you want to use 5V the set the Dip switches on the 107 board to output 5v.
    If you want to test this with crude setup then put a 1.5Vdc battery between 0v and 10v. (Or 0-5v spindle will just spin faster thats all)
    Then find the enable pins and put a NO switch on them to toggle ON/OFF.
    (Warning don't do any of this wiring live has the speed controller could be at mains potential)
  1. WANTED: Boxford 190VMC toolholders, tool changer and manuals
    By davethesteam in forum Items Wanted
    Last Post: 06-11-2017, 11:29 AM
  2. Kress Spindle upgrade to a 2kw
    By Metal pecker in forum Kress Milling Motors
    Last Post: 05-05-2014, 12:22 PM
  3. Upgrade
    By Dopy in forum General Discussion
    Last Post: 09-11-2011, 01:57 AM
  4. BUILD LOG: Time for mk2 upgrade!
    By routercnc in forum DIY Router Build Logs
    Last Post: 26-02-2011, 11:38 PM
