    I'm looking to make a motorized linear system to move a video camera (< 5kg), about 1m long. I'm a total newbie with this kind of thing but I thought a leadscrew and nut would be a good way of doing it.
    For the intended use, I guess the accuracy/backlash etc is not really a problem so I'm just looking for something cheap but fairly reliable.
    I was thinking of using SS leadscrew as it will be used in a domestic situations including outdoors. Is this 10mm leadscrew: http://www.worldofcnc.com/products.asp?recnumber=231 and this brass nut: http://www.worldofcnc.com/products.asp?recnumber=49 the right sort of thing to use?
    Any ideas, cheaper suppliers or help would be appreciated.
    V
    For a moving camera(If just surveilance?)Iwouldn't go for a lot of expense ie my choice would be stainless steel M12 threaded rod and associated SSnuts.
    http://www.leofixings.com/productdet...fBxU9vc=#tdimg
  3. Well Vikash that will work, depends on the speed you require and what levels of vibration you can withstand. What is your actual requirement?
    hi viklash.... heres my ten bobs worth.... i built somthing similar to carry an SLR but it was for a stop motion animation i was doing so it was hand cranked.... i used a builders level for the rail, cut a toothed printer belt and pinned it to one of the sufaces of the level, used one of the printer pullies as a drive and four small bearings ran on the inside of the builders level... super light weight
    if you want it driven.... id use an RC servo with a servo tester with battery pack... dial in the speed and a away you go... your audio will be goosed by the servo but im guessing you allredy knew this
    it shouldnt cost you much more than £50 in parts excluding the printer belt and pully.... if your interested in this low tec version let me know and ill try to get some pictures to show you what i mean (its stripped now but i still have most of the parts)
    It's for Videography, so smooth motion is imperative. I'll be mounting HD video camera with a pan/tilt fluid head which means there will potentially be some other forces at play during movement. No need for a stepper motor with precise control, just something that allows variable speed of movement ranging from very slow to perhaps ~5cm per second at the top end.
    At the moment I'm using a manual push system using a ball bushing carriage on an extruded aluminium extrusion - this doesn't lend itself to consistent, repeatable results.
    Perhaps I should try some SS rod from B&Q as a sort of proof of concept, but I assume 10 or 12mm trapezoidal leadscrew and nut would give far superior motion in terms of smoothness. Even a ballscrew is not out of discussion, although I'd prefer spending as little as possible for the results I'm after.
    V
    Got a feeling that gear&rack will be the smoothest for this along with speed and slow tracking into the bargain.
    The rackis the dearest component but willbe a lot better choice for me over leadscrew.
    If moving the camera in an arc is ok the old servo satellite gear could be the answer. There are two methods diseq and jack method. Look up superjack on ebay, the jack method is usually stronger and should be available second hand because most sat people have gone over to diseq.
    What about some chromed rail (25 - 30mm from wicks and acetal rod bearings pulled back and forth with wire would be a much cheaper option and an easy build? like in a printer the wire can be wound a few times at one end and a tensioner at the other. The bearings can be whipped up on a lathe.
    Thanks for the replies.
    It does need to be motorized, so I'm not looking for anything to push/pull (only). I already use a push system (commercial design that cost £200 for 50cm) and I'm certain something better can be built for less.
    I briefly looked at the superjack thing, but I don't think it satisfies the variable speed requirement and couldn't see it extending from 0 to ~1m either.
    I thought the gear and track method wouldn't offer the finesse as slower speeds as a leadscrew/nut?
    Mark, not sure where your posts have gone, but the head I use is the 701HDV.
    These aren't strictly neccessary, but it would be nice if the system could be used manually as well as motorised (can a nut be pushed to turn a leadscrew easily?), and also it would be useful to be light enough to transport around!
    And would you believe it, someone's already done what I was thinking:
  1. Cutting Aluminium With A Cheapo 3020 CNC
    By Pointy in forum Metalwork Discussion
    Last Post: 05-05-2014, 09:59 AM
  2. Minimum PC requirements
    By manofgresley in forum Computer Hardware
    Last Post: 26-10-2013, 04:33 PM
  3. Accuracy Problem
    By richie00boy in forum Machine Discussion
    Last Post: 09-09-2013, 11:24 AM
  4. Machine bed accuracy
    By Colin Barron in forum Gantry/Router Machines & Building
    Last Post: 03-11-2010, 11:24 AM
  5. Replies: 18
    Last Post: 04-06-2009, 03:44 PM
