Page 2 of 8 FirstFirst 1234 ... LastLast
    Quote Originally Posted by Kip View Post
    Try a DMM and then wire them one way or the other...not both!
    Attached is a wiring diagram I sent someone else here.....hth
    Isn't this the Series connection? What I want is a parellel connection so how will that look like?
    Bruce, have a look at this mate:
    http://www.mycncuk.com/pdf/wiring.pdf
    That should help you out with the wiring of the bob, check you'v got all that right and then tonight ill give this a bit more time and work out what you need to do.
    Bruce, check your wiring to this:
    I've wired this exactly like the diagram. I'm going for a parallel connection so I've done.
    Blue+Red to A+
    Blue/White + Red/White to A-
    Green+Black to B+
    Green/White + Black/White to B-
    But someone else told me that it should be as
    Blue+Red to A-
    Blue/White + Red/White to A+
    Green+Black to B-
    Green/White + Black/White to B+
    I've tried that too and nothing. No improvement.
    This is happening on all 3 axises. I cannot get the motors to rotate smoothly, they are rotating in jerks.
  5. Wiring looks fine, and the current is set to 4.2 A so that should be ok also.
    The problem that you are seeing is a typical noise or low signal problem, or possibly both.
    These are the points you need to address:
    1) Use Shielded cable for all signal cables
    2) Shield the motor phase cables.
    3) keep signal and power / phase cables apart, and if they need to cross, they should cross perpendicular.
    Also check the signals from the pc, the voltage should be about 5V, it it is low the driver can miss pulses and you can get the stuttering you are seeing.
  6. I just had an email from Bruce, and it apears that his clock pulse is about 3.3V, and he is using a laptop.
    This is most definately the problems, and is actually quite common when a laptop is used.
    The solution would be to use either another laptop with higher voltage outputs, or a desktop PC with a parallel port.
    Bruce,
    Try this and give us your results.
    Gary
    Quote Originally Posted by bruce_miranda View Post
    Aiming for Parallel and don't know what the wiring should be. So any help with be nice here.
    Gary from Motion told me that the SW4 was meant only for dropping current down to half after a phase but I'm so lost now I'll try anything.
  7. #17
    OK going to try and get my hand on a 'full' PC and see how things go.
    Does anyone know of a supplier for a buffered Breakout Board similar to the ones CNC4PC do but in the UK? Hopefully that will give me a full 5V signal and I can use my laptops again.
  8. Quote Originally Posted by Gary View Post
    Bruce,
    Gary
    What breakout board is he using? The MDS drivers are optisolated so dont really need a sophisticated BOB and are pretty immune to cross-over noise on the signal lines due to the low impedance 'on' drive. Unless he has a very long cable from PC to BOB or the BOB is a old design with TTL rather than CMOS logic I'd be suprised that the use of a laptop was an issue.
  9. Quote Originally Posted by bruce_miranda View Post
    Bruce - how are your drivers wired to the PC? The MDS series are opto-isolated. Unless there is some strange wiring issue a higher output voltage wont make any difference as they are active low drive.
  10. #20
    Lives in East Lothian, United Kingdom. Last Activity: 11 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,910. Received thanks 360 times, giving thanks to others 8 times.
    Model Engineers Digital Workshop have a couple of the CNC4PC cards in stock here.
  1. Replies: 0
    Last Post: 11-06-2014, 12:17 PM
  2. Leadshine 4-axis motor motion control cards? Any experience and info?
    By Boyan Silyavski in forum Motor Drivers & Controllers
    Last Post: 02-12-2013, 06:43 PM
  3. CNC Motion control
    By StoneyCNC in forum Manufacturer News
    Last Post: 26-08-2013, 10:07 AM
  4. 2x Motors, 2x drivers. How about breakout?
    By Tenson in forum Motor Drivers & Controllers
    Last Post: 20-09-2012, 03:21 PM
  5. Time for a purpose built motion control computer.
    By GeoffV in forum General Computing
    Last Post: 08-11-2010, 01:11 AM
