Thread: my build from the start
09-01-2011 #81
09-01-2011 #82It doesnt matter where you draw it in CAD you just put it in the same place in Mach3
in CAM not "CAD" you dictate atributes of the tool path, if your tool path starts in the center of a block you need to do a bit of maths phyisicaly place the tool in the center of the block to start
if your starting from a corner you only have to zero in on that corner set your hight and the gcode will jog to the centre and start cutting
09-01-2011 #83
cheers guys.
12-01-2011 #84
motor tuning is doing my headin :confused::confused::confused:
i want my motor to turn 1 rev and when it does, i want it to show 5mm in mach.
my motor is 200 steps 1/8 any help pleazzzzzzzzzzzzzzzzz
12-01-2011 #85
steps per = 320 errrrrm.... hang on, what micro step setting are you using on the board ?
its ages since i did mine, if your using 1/16 micro step and your screws are 5mm pitch then you have 1600 steps per revolution of your stepper that adds up to 5mm
devide your seps my 5mm to get your 320 steps per unit (1mm)
i think :)Last edited by blackburn mark; 12-01-2011 at 08:40 PM.
12-01-2011 #86
steps per mm = motor steps*microstep/screw pitch
For instance, 200 step motor, 5mm pitch screw and you say 8th stepping:
200*8/5=320 step/mm
13-01-2011 #87
13-01-2011 #88
Chris
The formula is 200 X (Micro Steps ?) = steps per rev
The amount the screw turns 1 rev (5mm i think in your case)
In my machines i use 10 microsteps so the formula is 200 x 10 = 2000 / 5 = 400 steps per rev
The velocity in the Mach setup tab is the fastest you are allowing the machine to run in your case you have set it to 600mm per minute which is on the slow side
So if you divulge you micro step setting your figures can be confirmed but 640 (Your Setting) steps per equates to 16 microsteps and the generally accepted maximum is 10
Phil
13-01-2011 #89
how did i set it to 16 microsteps? is that the 1/16 setting on the board, and i need to change it to 1/8?
i have set the dips to the 1/8 setting at the mo.
this is from the post on these boards
"The 1/8 step was reversed with 1/16, a fairly minor problem but still irritating as I had a scaling error on movement until I figured it out."
by the way a BIG thanks to all that have helped me so far.Last edited by h4ppy-chris; 13-01-2011 at 01:31 PM.
there is no such thing as a stupid question, just stupid answers !!!!
13-01-2011 #90
Well if you have it set to 1/8 then steps per rev = 320
Phil
Sent from my HTC Desire using Tapatalk
Well here we go again, start another build
By D-man in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 22-01-2014, 09:59 AM -
Build log when to start posting on this site
By ramsbury in forum General DiscussionReplies: 6Last Post: 15-01-2014, 10:43 AM -
NEW MEMBER: Hello all, finally ready to start a build log.
By Iwant1 in forum New Member IntroductionsReplies: 11Last Post: 25-12-2012, 06:03 PM -
A few questions before I start my build
By eclassic in forum General DiscussionReplies: 0Last Post: 11-07-2011, 10:54 PM -
NEW MEMBER: Were do I start?!
By tonygagey in forum New Member IntroductionsReplies: 4Last Post: 07-08-2010, 07:55 PM
