Thread: Digitizing
Good day all.
I am wanting to start learning how to do Digitizing?
I have a few things that I want to try digitizing.
To start with I was thinking piston crown, and flywheel.
But I don't know where to start.
I don't have a multiaxis probe, so I will be doing it the cheap way, grounding the item, and using a 1mm tool connected to the probe port.
So I would like you help and advice, on how to get started.
Thanks for your time.
Best Regards."If first you don't succeed, redefine success"
06-01-2011 #2
Only thing relating to digitizing I've ever stumbled across, is the video digitizing board on the mach forums - http://www.machsupport.com/forum/index.php?board=67.0
06-01-2011 #3
I havent tried any scanning myself but i have heard that the probe method can run into hours scanning relatively small parts then you need point cloud compatible software to make sense of the file.
Maybe have a look here http://www.david-laserscanner.com/
Phil
Mach3 digitizing wizard not saving file
By dudz in forum Probing, Digitizing & ScaningReplies: 0Last Post: 08-09-2013, 09:48 PM -
Digitizing probe / Point cloud to mesh
By dudz in forum Probing, Digitizing & ScaningReplies: 4Last Post: 07-09-2013, 10:03 PM -
Digitizing probes practicality
By dudz in forum Probing, Digitizing & ScaningReplies: 2Last Post: 04-06-2013, 03:31 PM -
Probing / Digitizing - What the best way to do this job?
By Mad Professor in forum Probing, Digitizing & ScaningReplies: 2Last Post: 08-05-2011, 12:32 PM
