    Ok Folks, Lead screw support bearings (fixed end) ... a pair of single row angular contact or a solo double row bearing??? that is the question.
    Answers, as simple as possible but with reasons please.
    Tim G-C
    “I disapprove of what you say, but I will defend to the death your right to say it.”
    (attrib. Voltaire but written by Evelyn Beatrice Hall "The Friends of Voltaire" 1906)
    C_Bubba's Avatar
    Lives in LaGrange, GA USA, United States. Last Activity: 18 Hours Ago Has been a member for 9-10 years. Has a total post count of 78. Received thanks 10 times, giving thanks to others 2 times.
    Tim,
    a pair of single row angular contact bearings as you can eliminate any backlash. A single (inexpensive) double row bearing may or may not have backlash problems.
    Art
    AKA Country Bubba
    (Older than Dirt)
  3. The Following User Says Thank You to C_Bubba For This Useful Post:
    I'm interested in the answer to this as I am at the design stage too
    do you have a picture for the hard of thinking?
    there are 10 sorts of people in the world
    them as understand binary
    and thems as doesn't
  5. #4
    Quote Originally Posted by mmcp42 View Post
    Have you checked your blog ?
    Phil
  6. #5
    OK thanks for that ... I was leaning toward a pair of singles as that seems to be what most folks opt for ...
    Tim G-C
  7. #6
    Quote Originally Posted by M250cnc View Post
    Phil
    indeed I have
    would still like a picture though!
  8. #7
    iv got single a/c bearings on my x axis screws at the moment,,,, im having problems with them being to tight on the shaft (my mistake) if i put to much tension on them i wont be able to back them off :( and to take them off the shaft i will damage them. anyway they have been a pain in the jacksy
    iv bought two double row A/C's to put in (when i find the time) the only disadvantage iv spotted with the double row is there are fewer balls so lower stress raiting... i cant see this being a problem, they will have a very easy life on a router
    if your getting any backlash worth mentioning with double row a/c I'd suspect that some cheeky sod has sold you double row deap grove bearings as angular contacts or they are duds
  9. #8
    Cheers, I'll bear those points in mind ...
    Tim G-C
  1. wobble / wiggle on ballscrew double row angular contact bearing
    By dsc in forum Lead Screws, Nuts & Supports
    Last Post: 14-12-2013, 08:35 PM
  2. Video of CNC machining a double sided part.
    By Shinobiwan in forum Woodworking Project Showcase
    Last Post: 17-03-2013, 11:23 AM
  3. Double gantry idea, What do you guys think?
    By craigrobbo in forum Gantry/Router Machines & Building
    Last Post: 25-12-2012, 10:01 PM
  4. Single Flute vs. Ripper
    By Tenson in forum Tool & Tooling Technology
    Last Post: 16-04-2012, 09:51 AM
  5. Double sided machining
    By CraftyGeek in forum General Discussion
    Last Post: 08-12-2009, 11:04 AM
