Thread: Hacking a Roland CAMM3 PNC-3000
25-09-2020 #31
Is there any more information on this?
I've just bought one and was reading through and then it stopped.............
Would love to hear more
Snowy
26-09-2020 #32
I can run the motors so X,Y and Z all arrive at their target simultaneously, I can read all the buttons and quadrature encoders, I can light the lights and stuff. I can read a sequence of positions and speeds from a serial host then execute them as a tool path.Whether that is of any use to you rather depends on whether this next bit looks like something you could understand...
; Home: Go to the limit switches then return
Home:
ld hl,0 ; zero coords so we get the return offset
ld (Xcoord),hl
ld (Ycoord),hl
ld (Zcoord),hl
ld a,4 ; Set the sequence so it starts
ld (hseq),a ; with a lift
ld hl,NmiHome ; Tune in to the Home service
ld (NMI),hl
call NotIdleLoop; ; returns when stepping is complete
ld hl,0 ; We started from zero so the position
ld de,(Xcoord) ; counters will have the distance moved
and a ; To get a return co-ordinate we need
sbc hl,de ; to reverse the counts.
ld (mX),hl ; subtract the position from zero
ld hl,0 ; repeat for Y
ld de,(Ycoord)
and a
sbc hl,de
26-09-2020 #33
Eh?, that looks like Z80 (if I can remember 40 years ago)
26-09-2020 #34
26-09-2020 #35
Removed.
26-09-2020 #36
I'd rather rather do Z80 Assembler than STM code using HAL, I like to get down and dirty
27-09-2020 #37
Removed.
27-09-2020 #38
Sorry chaps, didn't realise I was feeding a troll
08-10-2020 #39
Hi Robin,
I had a Specy 48k+ but i was 7 at the time. Not a scoobie.
Do you have any paperwork or manuals you could share? i haven't started stripping it down yet, don't even know if its steppers or servos and if they're worth keeping, what are the collets? i'm thinking a possible swap to linuxcnc to get it moving, whats your thoughts? i could donate the electronic gubbins to you if they'd be off use. i think it's only of use to me as a hardware frame as i don't have the know how for diggin into the electronics of it.
Snowy
08-10-2020 #40
It is 400 step/rev steppers so it purrs.
There ar 3 manuals:-
User's Guide
Command reference manual
Service notes (Which includes the full circuit diagram).
I could swap you a set of collets for the front panel with all the knobs and switches on.
You won't be needing them unless you take my firmware hack
NEW MEMBER: Yorkshire based modding / hacking noob says hello
By dynamis_dk in forum New Member IntroductionsReplies: 8Last Post: 27-02-2014, 11:03 PM -
FOR SALE: Roland CAMM3 PNC-3000 Desktop Mill
By danielbriggs in forum Items For SaleReplies: 4Last Post: 25-01-2012, 06:14 PM -
FOR SALE: For Sale! Roland PNC 3000 milling machine
By fidia in forum Items For SaleReplies: 17Last Post: 26-07-2011, 10:07 PM -
NEW MEMBER: Hi From Oxfordshire - with Roland CAMM3 machine
By rowifi in forum New Member IntroductionsReplies: 1Last Post: 15-02-2011, 05:04 AM -
Cheap for hacking
By Robin Hewitt in forum General DiscussionReplies: 12Last Post: 21-11-2008, 01:30 PM
