    Anyone ever used the CIB Industrial Control Interface board from Zapp Automation with Mach3 software?
    What do people think of the board?
    http://www.slidesandballscrews.com/i....html?cPath=54
    http://www.cnc2all.com/control-card-eng.html
    Ant
    Ant never used that board, but it should not be used with stepper drivers that have opto-isolation as well.
    Industrial control interface AKA breakout board
    Phil
  3. yes it can be used with stepper drivers that have optically isolated inputs.
    Any driver that is worth buying has optos built in.
    What is opto-isolation?
    Cheers,
    Ant
    Quote Originally Posted by antsals View Post
    Instead of there being a direct electrical connection between the computer and the driver the connection is effectively split with light bridging the gap. The opto-isolator uses an LED and a phototransitor to sense the light. If there is a high voltage on the motor side of the board it cannot reach the other side since there is a physical gap (within reason).
    Google it...
    You could get round the 'problem' of having both the driver and interface board isolated by buffering it - few logic gates, maybe not even that. Or even pop open the driver and bypass the isolation with a bit of wire! Kind of defeats the object of buying it ready made though, and you're increasing propagation delay which may/may not be significant.
    I was going to use these stepper drive units. It does mention opto-isolation. Will they be ok?
    http://www.slidesandballscrews.com/2...ml?cPath=44_97
    Also whats the reasoning that I can't use the opto-isolation. I've googled it but seems to be no-reasoning. In what solution would you use opto-isolation?
    Ant
  7. They work fine with the CIB.
    I wasn't thinking last night, disregard what I said earlier. I posted this diagram somewhere on the forum a while ago which shows how to do it:
    http://www.mycncuk.com/forums/showth...ll=1#post19932
    see post #22
  9. Connecting the CIB to any of our drivers is very simple.
    Connect pin 9 (5V+) to the positive side of the Clock, direction and enable and then connect pin 5 to the Puls, Pin 3 to the Direction and pin 1 to the enable (Free-)
  1. USB TO Parallel Port DIY Interface
    By Lee Roberts in forum Electronic Project Building
    Last Post: 17-02-2018, 07:46 PM
  2. Industrial router
    By Web Goblin in forum Milling Machines, Builds & Conversions
    Last Post: 13-02-2013, 03:31 PM
  3. NEW MEMBER: Cheap DRO using a USB interface
    By andyvail in forum New Member Introductions
    Last Post: 17-12-2010, 06:10 PM
  4. MPG Jog interface for Mach3
    By HiltonSteve in forum Electronic Project Building
    Last Post: 24-09-2009, 07:49 PM
  5. HID interface for remote control of Mach3
    By Smiler in forum Electronic Project Building
    Last Post: 10-05-2009, 12:59 PM
