28-08-2011 #51
is this the right power supply ?
please look at link
http://www.ebay.co.uk/itm/500-Watt-A...#ht_1856wt_905
James and Luke
28-08-2011 #52
No, an ATX power supply is a computer power supply so although the power is fine you only get 12V (and 5V, 3.3V and some others) which is not sufficient. You will get a much higher feed-rate if the motors are run on a higher voltage. You ideally want 70 volts.
28-08-2011 #53
I can't find the right power supply on farnell
I found a power supply 500w but only 48v ??
Help
rapid web site is down so I can't look on there
James
28-08-2011 #54
Would be OK, but since your drivers can accept up to 80V it's best to do that. I can't find any on eBay that are above 50V, so I think the best option is the transformer I linked to on Rapid in post #46:
Annoying that the site is down, but it's easy to get round - just use google cache:
http://webcache.googleusercontent.co...w.google.co.uk
28-08-2011 #55
Jonathan I will order the one from rapid on Tuesday
Will I need to order anything else for it (box) or will it fit in a old computer case along with my drivers and break out board
James
28-08-2011 #56
Computer case will be fine. Wire is cheapest from Rapid:
http://www.rapidonline.com/sku/Cable...119346/02-1066
(I'll buy the spare from you)
I emailed them and they said 2 weeks to deliver it.
Also for the power supply I'd get a bridge rectifier and terminal strip. I'll find them tomorrow when the site is working. They will also have suitable switches for limit switches.
28-08-2011 #57
cool thank you Jonathan
well Luke has been in the garage/work shop for most of the day drilling the legs ready for the stepper mounts
to say he loved it is a understatement at the end of it I received the biggest hug,smile and kiss ever and as he was walking out the door he turned around as said dad " it's been the best day ever dad I love you"
I've taped the motor mounts with just a couple of mm to go but that's for Monday and Luke to do
Jonathan that jig worked really well
I think I've had the best day of my life as well
James and Luke
28-08-2011 #58
I have a spare torodal transformer and some 4700-100v caps and probably Br-rec that will get you 70+volts if you haven't bought them yet.
The torod is almost new I think it's 1000va but will have to dig it out to get full specs to be sure then i'll be able to work for you the exact volts + amps.
I think i've got 4x caps which can be wired parallel and If memory serves me I think this transformer and 4 caps was giving me around 76 ish volts and 14A ish.
PM me If this is any use to you and I'll give you my contact details.
28-08-2011 #59
James,
what about something like this: http://www.antekinc.com/details.php?p=317
Ian
28-08-2011 #60
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
