    Tutorials
    I think it would be a good idea if the people that can would give Tutorials on how to turn a drawing into a working cutting example
    Ie
    one of my first jobs is the cut a quadrant out of maple
    3" piece of square wood by 1 meter
    so you draw the 3" by 1 meter on a 2D program and then what?
    how do you translate a curve to the x-axis/cnc program ??
    I think it would be really helpful to us beginners if some one did a project for us all to follow
    what do you experts think
    James and Luke:confused::confused:
    Just off out now but I'll do one tonight using Draftsight and Vectrics Cut 2D if that suits ?
    Post a bit of a sketch of the shape if you can.
    John S -
  3. The Following User Says Thank You to John S For This Useful Post:
    thats not a bad idea, i could have done with some of that when i first started, i think most of us built and just had to have faith that we would be able to sort the cad/cam problem
    it can be a nightmare at first but if you have the gumption to finish a build you definatley have the gumption to crack a bit of cad/cam (scuse the pun:naughty:)
    nice one john, it will be interesting to see how other people go about the task
    even a Video walk through ??
    vids are good but that would take quite a bit of effort for someone
  5. #4
    I never watch videos of people showing you how to use a program. They're almost exclusively slow and inefficient. If the program in not intuitive then I find the 'paper' tutorial, or help file. It's so much easier and quicker to just skim that document to find the required information than follow a video.
    For Vectric there are these pdfs:
    http://www.vectric.com/WebSite/Vectr..._tutorials.htm
    Luke: I'll show you how to do it in person when the time comes. For that particular part you'll probably have to export it from the CAD program as an STL and import into whatever CAM program you choose...
  6. #5
    Everyone has their own way of learning. Sometimes you just need to see something happen. I'm not a big fan of video tutorials for software in general but they have a useful place alongside written tutorials. There have been a few things that just didn't make sense until I saw it done.
    If by "slow and inefficient" you mean that the tutorials do not take the shortcuts you use, then you are missing the point. Learn first, get fast later. As long as the tutorials are not giving blatantly bad information then they are fine. Once someone has built up some experience with the software, they are ready to learn the shortcuts.
    There are some very good video tutorials for SolidCam that I found to be an excellent complement to the written materials (and can be found here if anyone is interested: http://www.solidcam.com/solidcam-professor.html). Each to their own, one supposes.
  7. #6
    i did a bit of solidcam professer and the tutorials and the help files, it still boggled the s**t out of me for a good while
    im not sure good cam software is intuative, soidworks is pretty easy to get into but solidcam is a bit of a **** .... you cant play it by ear at all but it starts getting petty slick once you press the right buttons and twiddle the right knobs :tup: it takes a bit of heart ache and pain first though
    (i never could get it to make any sense of my 4th axis)
    when i say "good" cam sofware i mean exotic... for doing acrobatic tool paths and all sorts of posh graphics for simulations.... probably a bit over kill for most and very very over priced for us mear mortals :)
  8. #7
    Hmm, looks like my comment was a bit controversial ...
    Quote Originally Posted by Rogue View Post
    If by "slow and inefficient" you mean that the tutorials do not take the shortcuts you use, then you are missing the point...
    That's not what I meant at all, in fact I don't use that many shortcuts - only the obvious ones. What I actually meant is that it takes a lot longer to attain the required information from a video compared to skimming through a document. In general I would get bored watching someone gradually explaining everything to find what I want. For a lot of things with these programs all you really need is a list of which buttons to press ... e.g Edit->arrange->Put to back. Since that's often included in help files or tutorials I just use one of my favourite shortcuts, Ctrl+F, to find them.
    Clearly some videos don't fit my description, just as some help files are not so effective. I could count the number of software related videos I've watched on one hand, and before someone says you can count to 63 on one hand I'm not using binary.
    Once you've used a few CAD/CAM programs they're all the same really and generally quite straightforward to pick up, as I indirectly demonstrated to luke11cnc last weekend.
  9. #8
    that so cool Thank you John s
    James and Luke
  10. #9
    But what do people think a bout doing a series of tutorials
    James
  11. #10
    OK glad to see Johnathan has sorted you.
    John S -
  1. Drawing of water cooled spindle
    By GTJim in forum Spindles & Drive Motors
    Last Post: 11-02-2014, 04:21 PM
  2. How to generate Lathe GCode from a drawing?
    By Robin2 in forum Computer Software
    Last Post: 25-10-2013, 04:04 PM
  3. Aspire tutorials supplied with the installation dvd
    By habibuzziwa in forum CAD & CAM Software
    Last Post: 17-11-2012, 03:38 PM
  4. Programming Denford TRIAC from a drawing !
    By edwardsjc in forum Machine Control Software
    Last Post: 15-03-2012, 09:29 PM
  5. drawing to g-code
    By ptjw7uk in forum Programmers Corner
    Last Post: 21-06-2009, 12:49 AM
