08-11-2011 #1
Basically I've got a bog standard router like below:
http://www.screwfix.com/p/direct-pow...ter-230v/25568
What I want to do is insert a cutter into the router but the shaft is only 3mm and the collet on the router is alot bigger.
Can anyone tell me if I can get a sleeve to adapt it and if so where from. The like of screwfix and B&Q dont seem to do them.
Matt
just type collect in to ebay
try this link
http://www.ebay.co.uk/sch/i.html?_fr...All-Categories
James
10-11-2011 #3
I think 3mm is 1/8" but I'm sure some one will correct me if I'm wrong
so you need 1/8 to 1/4" collet
James
10-11-2011 #4
10-11-2011 #5
That looks to be the same as B&Q's Performance Power range of routers.
Trend do make collect sleeve's, but I ended up using my friends mini metal lathe an make my own collect's."If first you don't succeed, redefine success"
10-11-2011 #6
I made some for mine using CNC mill operated as a cnc lathe. Could have made them manually on the lathe easily enough...I'll see if I can find them as I have no use for them now.
Edit: Looks like I videoed it, see here...
http://www.youtube.com/user/Jonbliss...17/m98fPg-_vUU
For future reference if you can't remember it's 1" to 25.4mm then use Google:
http://www.google.co.uk/search?gcx=w...w=1366&bih=667
(There's various ways you can type it and it will convert pretty much anything, for instance:
http://www.google.co.uk/search?gcx=w...w=1366&bih=667)
Considering the runout on those routers saying 3mm is 1/8" is not far off!
66 Piece TCT Router Cutter Set for £120 on Rutlands website for 48 hours
By WandrinAndy in forum Marketplace DiscussionReplies: 4Last Post: 30-08-2012, 11:41 PM -
Lubricant for router cutter?
By Richie in forum Tool & Tooling TechnologyReplies: 7Last Post: 28-04-2012, 12:26 AM -
cutter for MDF
By deannos in forum Tool & Tooling TechnologyReplies: 5Last Post: 16-10-2011, 09:33 PM -
First Plasma Cutter
By antsals in forum Plasma Table MachinesReplies: 3Last Post: 16-05-2011, 07:58 AM -
RFQ: Looking for someone to design and build me a cnc pipe router/cutter
By D-man in forum Projects, Jobs & RequestsReplies: 0Last Post: 07-11-2010, 01:59 PM
