    Hi all,
    Does anyone know where i can buy a new manual tapping machine?
    Thanks,
    James
    Get down to Aldi and buy the drill stand, then make one :-)
    I Just do them by hand, you could toy with a drill press / pillar drill but its tricky on your own.
    i2i's Avatar
    drill press and a cheap inline battery screwdriver. Remove the battery and use a power supply with a footswitch.
    http://www.chronos.ltd.uk/acatalog/6...ttachment.html
    + drill press and some machine taps.
    Tom
    Sherline lathe, Chester DB11V lathe, Myford/ Rodney mill, CNC mill Isel/ home made, Sealy Hack Saw, Meddings Pillar drill.
    Same... not difficult to get the tap orthogonal, unless I suppose you're drunk or something.
    Lately (past few months) I've taken to using the battery drill (dewalt something) on the low speed range. I now use it just for aluminium and M5 to M8. The chuck doesn't appear to be able to hole the tap tightly enough to break the tap. Not broken a tap, though they do sometimes get warm, with it yet and it's so much quicker!
    Mmmm! i wonder how may taps you have snapped Jonathan? Yes it works but not a good practice because when the tap bogs down you get kick in the drill and they snap. I will admit i do use the same practice but make sure i use all three taps in its range, but i still would not condone the practice.
    Quote Originally Posted by 2e0poz View Post
    None with the drill, but yes I've broken a few by hand. It happens.
    Forgot to mention that yes, it does help to use all the taps whereas by hand you can often get away with one. If it's important that the thread is good I'll do it by hand.
    I made one similar to that described at mikesworkshop from an old Dremel drill stand about seven or eight years ago and haven't broken a tap (down to 12 BA or 1.3 mm in new money) since then.
    Russell.
  2. RFQ: CNC drilling/tapping
    By Wal in forum Projects, Jobs & Requests
    Last Post: 17-11-2013, 07:13 PM
  3. Which is easier to machine on a manual lathe 12.9 or EN24 steel?
    By newtoid1986 in forum Metalwork Discussion
    Last Post: 18-09-2013, 07:20 PM
  4. WANTED: small(ish) manual milling machine
    By diy-john in forum Items Wanted
    Last Post: 22-02-2011, 09:04 PM
  5. Tapping Gcode
    Last Post: 14-12-2010, 07:07 PM
