Thread: Motor? Winch? Other?
14-02-2012 #1
I'm looking to lift / lower a load of about 20 or 30 kg, 2.5 metres in about 15 - 30 seconds... I did think of a 4x4 12v type winch, but also thought there might be an easier / cheaper solution???
Any thoughts from the collective on an elegant and efficient solution?
TIA
14-02-2012 #2
C4 or Semtex should do it nicely. .
Can you counterbalance it?
The Following User Says Thank You to Robin Hewitt For This Useful Post:
14-02-2012 #4
Lidl are doing some 250kg electric hoists with some form of jib [ not undone that box yet ] for £59.99
Already have one on the big CNC for lifting the vises and 4th axis on, both weight best end of 70 kg each.John S -
The Following User Says Thank You to John S For This Useful Post:
14-02-2012 #5
hmmm counter balance is an interesting avenue!
It's an application a little bit like a "loft hatch", although it's in an outbuilding... Instead of the "loft hatch" shaped hole in the ceiling, I'm thinking of a millers hatch... not sure if that's the right name but the hatch they use in windmills...
14-02-2012 #6
John, do you have a link to that?? doesn't look like my local Lidl is doing it.. nothing I can see on their web site , but sounds ideal! Thanks
14-02-2012 #7
No not on their web site any more, it was on offer last Monday so they just might still have stock, try a phone call.
It's a two pack deal, one box contains the winch, identical to this one.
http://www.machinemart.co.uk/shop/pr...ic-power-hoist
And a second box with a swivel jib in it. As I say I have not undone that one as I'm building one onto the small TOS lathe for lifting big electric motor rotors into the chuck and to be honest the jig looks a bit flimsy.
I really need about 350 to 400 kg lift so I'm going to build another set of falls into the cable lift which should give me a safe working load of 500kg.John S -
14-02-2012 #8
yep, thanks for that John!
Google brought up some of that info, including an email help address so I've sent the question off to them, I'll ring the local branch in the morning too.
did find this too, although you probably have already seen it??
Specifications: Payload: 125kg without pulley or 250kg with, Lifting height: 11.5m without pulley or 5.7m with, Rope speed: 8m/minute without pulley or 4m/minute with, Hoist lever arm: 600kg at 750mm and 300kg at 1100mm
14-02-2012 #9
Didn't see that spec but I already have one of the winches and it does a good job.
You really need to run it as a double cable i.e. 250 kg load as in single cable mode it a bit fast.
Don't fancy that jib at 600 kg at 750mm, it's only a bit of poxy tube held together with an exhaust clamp. I value my feet more than thatJohn S -
14-02-2012 #10
Counterweights are the standard way of flying theatre scenery, mebbe something adaptable;
http://www.ia470.com/primer/flies.htm
one thing to be aware of with counterweights is leaving carrying side unloaded, if its unbraked it will head for the roof carrying anything or anyone attached.
Adam
AC servo motor to replace a 3 phase induction motor on a mill spindle.
By rnr107 in forum Spindles & Drive MotorsReplies: 2Last Post: 23-04-2014, 03:14 PM -
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
servo motor as spindle motor
By Scott in forum General DiscussionReplies: 1Last Post: 03-10-2010, 06:42 PM
