24-03-2012 #1
Hello
This tool came with my milling machine a year ago
# For reference, picture of the milling machine. It takes MT3 -tools.
Seller thought the tool is for sawing bits, but could not remember what kind of tools could go with it. Can't blame him though for not remembering, it's been a year since I bought the machine
This picture shows, how badly the bits fit together (it is difficult to center the pieces, they don't sort of fit together)
Here parts are separated on a table:
This picture shows diameter of the "shaft" (metric scale)
Hoping one could use this tool for split -cutting items. Like this perhaps:
http://lh4.ggpht.com/_vxp-DxcoOlo/TR1oGLJKlvI/AAAAAAAAAgo/wruVyulXkck/Slitting Saw DIY TTS 1.jpg
Please would someone know what kind of sawing bits one could use in it? (if you think the tool indeed is for sawing)
Thanks for looking!
24-03-2012 #2
Check what diameter it is then buy a slitting saw to suit.
I use one of these from Arc Euro which is essentially the same thing. I use it for spindle mounts and shaft couplings, among other things.
http://www.arceurotrade.co.uk/Catalo...aws-and-Arbors
Unfortunately it has a lot of runout - should have made my own.
25-03-2012 #3
25-03-2012 #4
Does that holder have a keyway? You can saw without a keyway, but hand feed it until you trust it. That way you can can stop if it does.
Brass cuts easily, iron will require coolant. I like low rpm for slitting and buckets of lube.
Thin blades can flex. If you want to cut deep do a shallow groove first to support the blade.
02-04-2012 #5
Robin, the tool has no keyway. Shaft is half-an-inch (12.7mm). Finally went to my garage today, and got a chance to measure it.
- Really appreciate the tips on using these tools, have no prior information, apart from having seen videos on youtube.
Thanks!
help me identify this please
By wilfy in forum General DiscussionReplies: 11Last Post: 05-02-2013, 11:26 AM -
Can you identify this paint on metal finish..?
By Wal in forum Metalwork DiscussionReplies: 2Last Post: 29-01-2013, 06:25 PM -
Fancy a screw? Identify this leaky biatch!
By Lee Roberts in forum General DiscussionReplies: 8Last Post: 30-08-2012, 09:57 AM -
How would I go about making a jig to grind carbide V cutter/engraving bits?
By HankMcSpank in forum Tool & Tooling TechnologyReplies: 2Last Post: 12-03-2012, 12:39 AM -
What mill bits?
By icedfusion in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 16-10-2011, 12:25 AM
