03-04-2012 #51
03-04-2012 #52
4 times the price
03-04-2012 #53
...and not even than good.
03-04-2012 #54
04-04-2012 #55
Hi Jazz i have looked into this for you and i can confirm that Jonathan edited your post, for some reason there is no "edited by" note on your post like there should be.
To clarify there is only Myself, Irving2008 and Jonathan with access to "post editing" as Jonathan has now joined us as a member of the moderating team.
.Me
04-04-2012 #56
Lee does this mean that all post must now run with 10mm pitch screws and run at a thousand miles an hour?
04-04-2012 #57
Just to add,cost of the machine is one part of the equation, software is the other.
Ran a licence for Mach3 down to 115 GBP on ebay, without a licence your limited to 500 lines of code,which might slow things down or linux EMC for free.
CAM software, its possible to go for a while on trials but eventually you`ll want to setlle on something, personally went for Meshcam, chew another 175 USD, which from my own survey is good value for what it does.There is a lot of other choices but figure around 100 GBP starting point....
CAD sotware, used Sketchup for a while for other uses, but beginning to figure its not great for conversion to CAM models, probably time to learn something more suited and eat probably another 3 figure number there....
Adam
Trials of YooFix it drivers detailed elsewhere ;-)
04-04-2012 #58
I've apologised to Jazz for the mistake - it was an accident. The 'edit post' button is right by the reply button and I hit the wrong one. Wont happen again, so 2e0poz is free to post about 5mm pitch screws!
If anyone edits their post within about 2 minutes of it originally being posted then it doesn't display the "edited by" note.
04-04-2012 #59
There are sufficient pieces of free software for most things. Two extremes are the free edition of CAMbam, which will only do 2.5D and CNCtoolkit which does anything up to 6-axis for nothing...
Can't really help on CAD software as I just use what I got from school, 2D Design V2. It's very user friendly and can draw pretty much anything in 2D, but I don't think you can buy it outside of education.
Just look for one that you export files as a DXF.Last edited by Jonathan; 05-04-2012 at 12:03 AM. Reason: Formatting
04-04-2012 #60
Musht for 2D thats free i use QCAD on Linux, there is a windows version here for free http://www.himili.com/blog/downloads...s-gpl-version/. I've never had any issues with this and it works well.
Draftsight is also another good one for free.If the nagging gets really bad......Get a bigger shed:naughty:
By Richard in forum Machine DiscussionReplies: 2Last Post: 18-02-2014, 04:18 PM
