hi ppl this gcode, a quick create if you will but stops after drill 1..
any one help heres gcode
http://dl.dropbox.com/u/20853399/test.nc?dl=1
been doing a dry run
hope you can help
19-04-2012 #2
Works OK for me.
Why are you using G2 moves to drill ?John S -
20-04-2012 #3
what do you mean.. g2 moves... i just did toolpath in cambam then gcode.
it seems to stop in mach3 on drill 1
20-04-2012 #4
( Drill1 )
S1000
G0 Z0.1
G0 X-40.0 Y40.0
G0 Z0.1
G0 X-37.6 Y40.0
G1 F300.0 Z-8.0
G2 F800.0 X-41.2 Y37.9215 Z-8.1333 I-2.4 J0.0
G2 Y42.0785 Z-8.2667 I1.2 J2.0785
G2 X-37.6 Y40.0 Z-8.4 I1.2 J-2.0785
G2 X-41.2 Y37.9215 Z-8.5333 I-2.4 J0.0
G2 Y42.0785 Z-8.6667 I1.2 J2.0785
G2 X-37.6 Y40.0 Z-8.8 I1.2 J-2.0785
G2 X-41.2 Y37.9215 Z-8.9333 I-2.4 J0.0
G2 Y42.0785 Z-9.0667 I1.2 J2.0785
G2 X-37.6 Y40.0 Z-9.2 I1.2 J-2.0785
G2 X-41.2 Y37.9215 Z-9.3333 I-2.4 J0.0
G2 Y42.0785 Z-9.4667 I1.2 J2.0785
G2 X-37.6 Y40.0 Z-9.6 I1.2 J-2.0785
G2 X-41.2 Y37.9215 Z-9.7333 I-2.4 J0.0
G2 Y42.0785 Z-9.8667 I1.2 J2.0785
G2 X-37.6 Y40.0 Z-10.0 I1.2 J-2.0785
G2 X-41.2 Y37.9215 Z-10.1333 I-2.4 J0.0
G2 Y42.0785 Z-10.2667 I1.2 J2.0785
G2 X-37.6 Y40.0 Z-10.4 I1.2 J-2.0785
G2 X-41.2 Y37.9215 Z-10.5333 I-2.4 J0.0
G2 Y42.0785 Z-10.6667 I1.2 J2.0785
That's not drilling, it's pocketingJohn S -
20-04-2012 #5
here ya go cambam toolpath
http://dl.dropbox.com/u/20853399/test.cb?dl=1
20-04-2012 #6
John S,
Yep you are completely correct on that one. CamBam will pocket a "drill" hole where the end mil is smaller in diameter then the required hole and as you can see it does it in a spiral pattern. Works rather well on the code I use and will drill when the endmill is the same diameter as the hole. Rather interesting code structure on that part. As to why it is stopping I don't know as ran fine for me as well. Could be that the OP is getting a false trigger that is causing the problem. Well have fun folks.
Michael
20-04-2012 #7
it also seems there is some of my project missing,when i load the gcode, the peice that is displayed has the outer ring missing
is this normal
cheers
20-04-2012 #8
You say it stops after (Drill1).
And that you are missing part of your project.
That would hint that you are using Mach3 in demo mode (500 line limit)."If first you don't succeed, redefine success"
20-04-2012 #9
so how do i get out of demo mode... i got this copy with my drivers....
20-04-2012 #10
You will need to purchase a Mach3 license: http://www.machsupport.com/purchase.php
The Following User Says Thank You to Mad Professor For This Useful Post:
Some Gcode generating programs
By Jonathan in forum Programmers CornerReplies: 20Last Post: 28-02-2014, 07:58 AM -
Help needed for a 3d part gcode for mach3
By Rebekah_harper in forum Computer SoftwareReplies: 33Last Post: 04-11-2013, 01:55 AM -
How to generate Lathe GCode from a drawing?
By Robin2 in forum Computer SoftwareReplies: 18Last Post: 25-10-2013, 04:04 PM -
Tapping Gcode
By Kai in forum General DiscussionReplies: 10Last Post: 14-12-2010, 07:07 PM -
PLease help - gcode newbie
By scotty in forum Programmers CornerReplies: 3Last Post: 07-03-2010, 12:48 PM
