    Hey guys, I have ordered a chinese cnc 3040 with a 1.5kw spindle.
    I am wondering from owners of the watercooled 0.8kw 1.5kw and 2.2kw could tell me if you have ever dismantled one?
    The one i bought comes with an ER11 collets, but there seems to be replacement collet system for spindles from ER11 ER16 and ER20 and i am wondering if they are actually interchangeable?
    Would anyone be able to supply detailed pictures and if possible show one dismantled and/or confirm they are changeable?
    If so which one its changeable from/to
    here is a link to just one replacement i found on ebay, but there are lots on there like it with different shanks (ie some taperd some straight)
    http://www.ebay.co.uk/itm/C16-ER20A-...item3f014a5d1d
    and
    http://www.ebay.co.uk/itm/ER20-MT2-M...item231c834a95
    Craig
    Quote Originally Posted by craigrobbo View Post
    Yes I have striped one and no they wont because of the way the rotor is part of the collet shaft.
    The different spindle KW and ER sizes etc make them completely different so therefore not interchangable.
    The ER shafts you link to are not replacenments but more extensions and adapters for drilling machines etc or building your own spindle. One of them is MT2 to ER adapter used on mills and lathes.
    Here's some pics of a 2.2KW I killed.!!
ID:	5964Click image for larger version.
ID:	5965Click image for larger version.
    I can confirm Jazzcnc statement. The chuck is integral with the main motor shaft. I have noth 0.8 kw and 2.2 kw and you just use whatever is on the end.
    Hey Jazz, How did you kill that 2.2?
    Hiya, Will the suppliers not supply you with a larger collet system if you specify it?
    As these items are mass produced I would doubt that a special would be considered. Even if it was, I would expect a hefty premium to produce a one off. It's not quite as simple as putting a larger shaft into to smaller motor casing as it simply doesn't fit.
    Ali Kat
    Quote Originally Posted by Ali Kat View Post
    My own silly fault, I'd had the spindle off a few times to check fit for some mounts I'd made for someone and didn't fasten the cable guide correctly, So over time the connector was bending and snapped wire inside main connector at the spindle causing dead short and great big blue flash.!!!!!. . . . . Killed both spindle and ABB350 VFD stone dead. .
    Whoa - expensive smoke!!!! Let me know if you want to part with the dead bits as it may be useful to have a couple of bearing housings on the spares shelf for my own 2.2.
    Ali Kat
    Ali Kat
    Nope sorry. It's going to be modified to belt drive then used either has a secondery slow running spindle for steel work or be used for the spindle of a mini lathe.?
    Just don't ask when.!!
    hiya, Yeah, they are mass produced... With different collets etc :) I would have thought the 'manufacturer' of the machine could just fit a different one...
    Its something I have done in the past.
    Quote Originally Posted by GMCNC View Post
    I would imagine because of the small rotor diameter of low powered spindles then the large ER collet systems wont fit or be enough material left to safely adapt.
    The cost to re-tool for an upgraded rotor for just a few specials wont be worth the expense in relation to demand.?
    How did you fit a larger ER collet taper system into a smaller ER taper.?
  1. Chinese 2.2 water cooled spindle / Which VFD ?
    By dudz in forum Motor Drivers & Controllers
    Last Post: 16-08-2013, 02:22 PM
  2. Chinese water spindle owners?
    By D.C. in forum Marketplace Discussion
    Last Post: 06-11-2012, 01:08 PM
  3. Plug for water cooled Chinese spindle
    By John S in forum Generic Chinese Spindles
    Last Post: 28-08-2012, 05:56 PM
  4. FOR SALE: 2.2KW Water Cooled Spindle + Inverter (yes the Chinese one!)
    By Bokoshoko in forum Items For Sale
    Last Post: 06-02-2012, 12:43 PM
