Thread: Chinese Spindles
27-05-2012 #61
Try theses http://www.spnd.com.tw/prod-e.html company called micro lab in taiwan, i had a quote last year for a M3-FPS Belt driven spindle that could run at 10K and that was $1000 these look very good quality units. they also do a load of other style spindles but again price is a big contender here!
27-05-2012 #62
Oooo thats a posh site.. and has some real goodies on it but i cant see any real spec sheets or a price list...
27-05-2012 #63
I would like 1.5 - 3hp motor, 6000 rpm, bt30 atc with grippers, all in one motor/spindle package if poss.
27-05-2012 #64
27-05-2012 #65
I think it's a safe bet to say Jazz and I would only be interested in the 15000rpm, BT30 spindle:
http://www.spnd.com.tw/pem3-fps.html
Realistically I just can't afford one, but lets see what the price actually is first... Also could do with getting a drawing from them.
27-05-2012 #66Always bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
27-05-2012 #67
it may be difficult to get a "low" rpm (6000rpm) spindle with the motor fitted.
27-05-2012 #68
27-05-2012 #69
Absolutely
There is one which I build. It takes MT3 ER20 collet chuck or anything with MT3. It's not final design, but gives idea how it will looks like. There will be MT3-like taper on the top to install set of reduction pulleys. I rather needs to go down with the speed than up so taper roller bearing will be perfect for this.
So far hollow shaft including M30/1 thread for preload nu,t internal and external MT3 tapers is turned. I'll try to make some pic of it.
27-05-2012 #70Always bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
The 2.2Kw Chinese Spindles - Info, Setup and Advice + More
By Husky in forum Generic Chinese SpindlesReplies: 222Last Post: 22-01-2021, 06:54 PM -
motor power and chinese spindles power HELP
By DigiSoft in forum Spindles & Drive MotorsReplies: 5Last Post: 17-09-2013, 12:17 AM -
Chinese spindles
By Colin Barron in forum Marketplace DiscussionReplies: 15Last Post: 23-08-2011, 08:58 PM -
Chinese 1.5kw Spindles
By jcb121 in forum Generic Chinese SpindlesReplies: 12Last Post: 28-07-2011, 06:20 PM -
NEW MEMBER: Spindles
By Johnp in forum New Member IntroductionsReplies: 4Last Post: 28-06-2009, 11:46 AM
