    As title
    Size is 395 x 170 and the alu thickness isn't critical - 17-20mm is fine. There are 26x M5 tapped holes to do but the rest is fairly straight forward profiling and pocketing.
    Ignore the spindle mount in these pictures, its the plate I'm interested in.
    I can supply the alu used for the plate or pay you for yours. Either way I'm paying for the the work involved.
    Ant
ID:	6342   Click image for larger version.
    Quote Originally Posted by Dom View Post
    Good morning,
    I know this was posted a while ago now but if you still require this to be made send me PM and i should be able to do it within the next couple of weeks. Do you have a drawing to work from? Alternatively, if that is a solidworks model i can import it straight in.
    I'm pretty sure from the StrikeCNC thread that Jazz made this part some time ago..
    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 2 Days Ago Has been a member for 9-10 years. Has a total post count of 280. Received thanks 2 times, giving thanks to others 69 times.
    Hi Dom,
    I am looking for a very similar Z plate to be made if you are interested in providing the Alu and making it for me ? (at my cost obviously)
    I have ordered a Chinese "80mm spindle" mount to go on it ;
    Top quality mount bracket Clamp 80mm diameter for spindle motor free shipping | eBay
    I will give you the exact dimensions when you confirm. Needs to be sent to N.France..
    I should be able to make it, but it will come with a long weight free of charge...
    If your going to be making these Jonathan I think I could probably use one as well, just need to know if you would be able to supply a spur lash as well as a long weight??
    dudz's Avatar
    haha, how long is the long wait ?
    How long is a piece of string...
    I've got a few other things I've agreed to make for people, so I can only do it once they are finished which will be at least a month so probably around Christmas.
    Quote Originally Posted by martin54 View Post
    I'm afraid not, it's too difficult to package, however I could include a left handed Allen key to help with assembly if that's any use?
    dudz's Avatar
    Sounds good. When the spindle collar arrives, I can give you the hole spacings etc.... 250mm tall, 160mm wide should do it? 15-20mm thick. How would I know if my Z axis can handle the weight of this spindle ?. The spindle is the same physical width as my whole Z axis, although with max force I can not feel any play or movement at all.
  1. push down plate,
    By jcb121 in forum Gantry/Router Machines & Building
    Last Post: 31-07-2013, 11:38 PM
  2. Front face DIY decals advice ..
    By Fivetide in forum Metal Finishing Techniques
    Last Post: 13-06-2013, 11:23 AM
  3. EXPERIENCE: Z Plate made by DOM
    By dudz in forum Trading Experience & Feedback
    Last Post: 28-11-2012, 08:12 PM
  4. what is aluminium plate
    By martin54 in forum General Discussion
    Last Post: 11-10-2012, 01:44 AM
  5. RFQ: Mounting Plate
    By ferus in forum Projects, Jobs & Requests
    Last Post: 26-10-2011, 02:56 AM
