I'v just recived one of these from a seller on ebay:
2GB USB flash / memory / data stick - swivel (black) - NEW
The Swivel has a metal sleeve over a soft touch rubber coated or transparent plastic body. The rotating sleeve protects the USB plug, no separate lid required.
Please note these are old stock of data sticks which may have some slight marks / scratches to the outer metal case, but are brand new and never used. (mine was in mint condition)
Specification:
100% new high quality 2GB Flash Drive Fold
Capacity : 2GB
Read 12MB/s and Write 8MB/s Compatible with All VR3 Products VRFM7 , VRFM8, VRFM9,VRCD400USB and VRCD400SDU Works on all Major Operating Systems, PCs, Macs, Laptops
Support Hi-Speed (480Mbps)
Mobile USB Flash Drive, USB 1.0/1.1/2.0 Compatible
No Drivers Required
Durable Solid-state Storage and Data Retention for at Least 10 Years
Low Power Consumption
Key Chain Dongle Design or Can Use Strap, Easy to Carry
Dimensions : 5.5cm (L) x 1.8cm (W) x 0.6cm (H)
Weight : 0.016 kg
Support Windows 2000, Windows XP, Windows Vista
The seller is nothing to do with me but i can confirm the sticks he is selling are A OK, and for £3 delivered you cant go wrong !
I only needed a couple of these to use as linux boot drives for somthing i'm working on, so 2GB's was more then enuff for me. If you need a massive amount of space then im sure there is lots of other better deals on the bay for bigger sticks but if you just want a quick, simple, CHEAP stick then grab some of these before they all go.
EBAY ITEM NUMBER: 140289282648
EBAY LISTING LINK: http://cgi.ebay.co.uk/2GB-USB-flash-...ayphotohosting
