Thread: servo control vs stepper control
14-09-2012 #21
Ok, so 5mA collector current on 5v, 24mA on 24v.. so it wont fry :)
EL817 optos are rated 35v, 50mA so should be ok.
However, as I recall the diode has a 330R series resistor so forward current is about 10mA and those devices have a transfer ratio of about 1.1. So with 10mA in the diode the collector current is going to struggle to be more than 11-12mA which means the output volts wont drop below about 12 - 13v, so though it won't fry its not going to work. No good on 24v :(
16-09-2012 #22
Help me out here a bit folks.
After trawling through 300-odd pages of servo amplifier manual which seems to have every bit of information you could possibly want for the Mitsubishi drive - I can't for the life of me get the faintest idea how it could be connected to accept step & direction commands from Mach 3. What is the usual command process for controlling servos?
16-09-2012 #23
Not all servo drives can handle step/dir. Analogue control is far more common in industrial drives, so you need a suitable interface to take the step/dir and convert them.
Search/ask on the Mach forum (www.machsupport.com/forum), as there are a couple people on there who know about servos.
16-09-2012 #24
17-09-2012 #25
Thanks Jazz
Lexium LXM05CD10M2
and
Mitsubishi MR-J2s-10A
Build Log: Servo Drive and VFD with vector control
By Jonathan in forum Electronic Project BuildingReplies: 17Last Post: 05-04-2015, 07:58 PM -
Speed control
By Saracen in forum Spindles & Drive MotorsReplies: 2Last Post: 29-12-2012, 02:18 PM -
NEW MEMBER: I am going to build a 3 axis servo control
By markey1979 in forum New Member IntroductionsReplies: 8Last Post: 16-11-2011, 12:53 AM -
Help with spindle control
By wizzy in forum Spindles & Drive MotorsReplies: 4Last Post: 12-02-2011, 12:51 AM -
Help! Stepper control board
By Ross77 in forum General ElectronicsReplies: 10Last Post: 28-05-2009, 01:42 AM
