    Here are some photos of a sawmill I built several years ago. Log capacity is 28" dia. and bed length is 20 feet. I can extend that with more sections, but generally use an Alaskan mill for long timbers. I built my house with lumber cut from salvaged downed trees on my property left by a really incompetent logging company, the prior owner. The mill took 2 weeks to build and cost about $800. It will cut a 18" x 16' long pine board in about 50 seconds. Hardwood somewhat slower. I run the governed motor at 2700 RPM, though it is rated at 3600.
    The fixed spindle is a trailer spindle. The drive is a go-kart axle and hub assembly. Driven wheels are trailer wheels and tires. The engine is a snow blower horizontal shaft Subaru-Robin 10 Hp type. Large reduction pulley is 2 sheave 15", and was a surplus item found for $15. The guides are made of 3 ball bearings. Two smaller sets that the flat of the blade rides against, and a larger bearing that the back of the blade contacts. The blade guard is a trailer fender. The vertical adjustment is made by a used boat trailer winch.
    I also built a log arch out of a mobile home axle and a bent heavy steel tube that I found at a scrapyard -- I think it was once part of the derrick for a tow truck. I couldn't straighten it, even with heat so I faced it up. I guess it is a log arch in two senses of the phrase!
ID:	6874   Click image for larger version.
ID:	6873   Click image for larger version.
ID:	6872   Click image for larger version.
ID:	6871   Click image for larger version.
  2. The Following User Says Thank You to vtcnc For This Useful Post:
  3. #2
    Do you tension the blade by inflating the tyres (tires) a bit more?
    Hello Boldford!
    That's a very frequent question. But no, the tires are maintained at constant pressure. The non-driven spindle has adjustments for both axial angle, and distance from the driven wheel (blade tracking and blade tensioning), just like an ordinary bandsaw.
  5. #4
    TrickyCNC's Avatar
    Location unknown. TrickyCNC Last Activity: Has a total post count of n/a. Referred 6151 members to the community.
    Very interesting ! I'll have to look into that and build me one :)
  6. #5
    Respect sir my name is Mahmutagic Nermin and I live in Bosnia and Herzegovina, on the website I found a picture of your machine for cutting wood, and I wanted to do something like that but I need drawings or sketches of your machine,
    Thanks and best regards from Bosnia
  7. #6
    Quote Originally Posted by vtcnc View Post
    bravo bravo
  8. #7
    I'm more impressed by the fact that you built your own house!! Awesome job.
  9. #8
    Fantastic!!! Well done. G
  10. #9
    Yep, another one is is impressed with not just the saw but the house as well. Thanks for sharing.
  11. #10
    Amazing, so not only have you built your own house, you're dropping trees, sawing the timber to size then using them to build it. The almost free house.
  1. RFQ: Parts need turning
    By ams in forum Projects, Jobs & Requests
    Last Post: 15-01-2014, 12:27 AM
  2. 2.2kw spindle parts
    By Tomnewry in forum General Electronics
    Last Post: 14-12-2013, 09:30 PM
  3. NEW MEMBER: CNC Router Parts
    By CRP in forum New Member Introductions
    Last Post: 29-10-2013, 02:37 AM
  4. RFQ: MDF parts required.
    By mZeles in forum Projects, Jobs & Requests
    Last Post: 25-10-2013, 01:28 PM
  5. RFQ: Some parts.
    By jcb121 in forum Projects, Jobs & Requests
    Last Post: 22-03-2012, 05:07 PM
