Thread: Sheetcam TNG
    Does anyone use Sheetcam?
    I bought this a while ago but never got round to trying it out.
    C_Bubba's Avatar
    Lives in LaGrange, GA USA, United States. Last Activity: 5 Minutes Ago Has been a member for 9-10 years. Has a total post count of 78. Received thanks 10 times, giving thanks to others 2 times.
    I have been using Sheetcam since the days of the original Sheetcam beta's! I find it easy to use and there is great support from Les the author. He has a forum, and a yahoo group and is very responsive. I especially like the fact that I can modify post processors myself for local conditions. He even gives very adequate information on how to do it!
    One very satisfied customer.
    Art
    AKA Country Bubba
    (Older than Dirt)
    Had a quick play last night. I like the idea of being able to add a finish pass. I just need to try it a few times to get it right. Do you simply type in the value of the finish pass size you need for the first operation to leave the material on the job, then select a new operation for the same contour and set the finish pass value to zero?
    C_Bubba's Avatar
    Yep, that's the way I do it. there is a "finish" allowance that you can set and it will leave that much (or if you want to make the cut oversize for some reason, put in a negative amount for the finish pass) Sometimes, I will use a "rougher" mill and then switch to a "finish" mill for the finish pass.
    Makes it easy to do as there are times the speeds and feeds will also be different.
    Art
    AKA Country Bubba
    (Older than Dirt)
    Thanks.
    I have been having a play with it today and so far I really like it. Just found the start point editor as well. Brilliant.
    C_Bubba's Avatar
    Be glad to offer my advice on anything I can, just take it for what it costs:})
    I find new stuff everyday and most of it comes from the yahoo forum.
    Art
    AKA Country Bubba
    (Older than Dirt)
  7. The Following User Says Thank You to C_Bubba For This Useful Post:
  8. #7
    Thanks. If I get stuck I will drop you a line.
  1. RFQ: 4 and 5mm steel plasma / laser cutting required, can send sheetcam files
    By nobby in forum Projects, Jobs & Requests
    Last Post: 29-04-2014, 12:36 PM
  2. Plasma, Mach3, Sheetcam and a Proma Torch height controller..
    Last Post: 14-04-2014, 03:49 PM
  3. RFQ: 5mm steel plate plasma or laser - can supply sheetcam g-code for mach 3,
    Last Post: 07-03-2014, 07:56 PM
