Thread: Which tap??
18-11-2012 #1
I will need to tap holes from m5 to m12 on my build in Ali and Steel... I was thinking of buying my first set of taps... What do people think of these ??
http://www.toolbox.co.uk/draper-4089...ign=GoogleBase
18-11-2012 #2
Oh an I had my eye on this rachet wrench too
http://item.mobileweb.ebay.co.uk/vie...d=120538092442
18-11-2012 #3
That rachet is OK, I would also get a longer one of the same type, very useful, gets your paws out of the road!
Peter
Taps look to be OK, best to only get HSSLast edited by ptjw7uk; 18-11-2012 at 04:57 PM. Reason: added notes
18-11-2012 #4
how does a ratchet work when your tapping then? i was taught to do 180 turn, then twist back a little to free the swarf then do another 180... if your using a ratchet i presume u just keep winding in till your done
18-11-2012 #5
18-11-2012 #6
A set like that would might be OK to start you off, but you're going to need to replace the ones you use/break most often.
I bought a comprehensive boxed set from M3 to M14 & replace when needed from MSC Industrial Supply Co..
18-11-2012 #7
I've been using these taps.....
HSS Tap Set M8 x 1.25 8mm | eBay
....and these drills
1 x 8.0MM COBALT DRILL BITS 8MM DRILLS TOP QUALITY | eBay
...today. Got about 50 holes of M6 and M8 drilled and tapped in ali and steel and the tools are just beginning to dull.
18-11-2012 #8
Thanks guys, now all I need to do is convince someone to fork out for christmas!!
19-11-2012 #9
Hi Wilfy
The ratchet is most useful when cleaning up lots of threads in awkward places. Ypur right on the 180 backwards when cutting new threads. I find the ratchet is also useful for those very awkward places where a normal tap holder cannot go, not easy flipping the ratcket but needs must as they say!!
peter
19-11-2012 #10
Morning Guys,
Typically I just buy what I need size wise as and when I need them, normally I would back the tap off a quarter of a turn then do my 180, I think some people use a little lube when tapping, personally I don’t bother.
As been said really I think the ratchet is most useful when doing your second and 3rd tap, not done any work with a bottoming tap to date so not sure a ratchet would make that job any easier.
Can’t say I’ve ever broke any either, would suggest using the right size bore for the tap you want to use.
.Me.Me
