Page 3 of 3 FirstFirst 123
  1. #21
    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 2 Days Ago Has been a member for 9-10 years. Has a total post count of 280. Received thanks 2 times, giving thanks to others 69 times.
    Ah ha.. probably these : x20 T-Nuts Slot 10 M6 1001 | eBay
  2. #22
    dudz's Avatar
    OK. These rails purchased...2 linear bearing slide unit SBR25-850mm rails+4 blocks | eBay
    I hope the quality is as good as the ones sold in the UK.
  3. #23
    You should have contacted Chai directly then you'd have got a better deal!!
    Most of the rails sold in the UK are imported from China anyway ;)
    Neil...
    Build log...here
  4. #24
    dudz's Avatar
    Ok.... I received my Aluminium via UPS. 470mm X 300mm X25mm
    I clamped it down to the original bent Vacuum bed (which temporarily straightened it)... planned the new supported rail bearing block mounting holes in CamBam and successfully drilled and counter-bored the holes. First thing I have ever done with this machine since changing the Z axis plate and adding the 2.2kw Chinese spindle. What an improvement so far !
    Still a way to go to make it more sturdy, but I am already planning the next improvements to come.
    Now... in respect of holes for clamps on the cutting bed.....For now I am going to drill and tap some holes for clamps. (maybe cutting slots later if needed). What size metric holes should I use for the clamps ? M4/M6 ?? and what depth ?
  1. BUILD LOG: 3 Axis Router
  2. BUILD LOG: 3 Axis CNC router
    By JoeHarris in forum DIY Router Build Logs
    Last Post: 21-06-2020, 10:41 PM
  3. 3-Axis CNC Router - For Helices.
  4. BUILD LOG: Wobbly: my first 3-axis router
