Thread: 6mm shaft to 6.35mm hole?
I'm repairing/upgrading a gadget, and the spare part choices are limited; therefore, the problem can't be solved by selecting other parts. So, I have a 6mm shaft and a 1/4" hole (6.35mm) in the pulley. There are two scrub screws, but I don't want the wobble. How would you do a snug fit?
Cheers,
Juha
04-12-2012 #2
Suggest you shop harder. If the 6mm or unbored pulley costs a few more quid it is worth it to save the aggravation.
15-12-2012 #3
There isn't a "nice" way to fit a 6mm shaft snugly into a 1/4" hole other than shimming or boring the 1/4" hole bigger and making some insert collars.
15-12-2012 #4
Like everyone says there probably isn't a good way of doing it, but if you want to do it a cheap way, get a coke can and chop out a small piece (you can use normal scissors) and plug the gap by making a collar.
David.
Hole Radius
By benkat in forum Machine DiscussionReplies: 0Last Post: 03-03-2014, 05:29 PM -
SBR16UU Centre hole.
By cambesol in forum Rails, Guideways & BearingsReplies: 3Last Post: 25-11-2013, 05:39 PM -
WANTED: Wanted - a 1/4" (6.35mm) ER11 collet.
By HankMcSpank in forum Items WantedReplies: 4Last Post: 17-09-2013, 07:45 PM -
hole punch for tobacco tin ideas please :) ?
By Fivetide in forum Metal Finishing TechniquesReplies: 22Last Post: 01-07-2013, 09:28 PM -
Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
By LoveLearn in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 08-02-2012, 01:52 AM
