06-12-2012 #6
Provided you use some metal that is stress reliefed, then 2thou run out is fairly easy.
I can't remember of the top of my head if the usual stainless bars (303, 304, 316) are stress reliefed or not. Non-stress reliefed can be used, however it may distort over time, or if subject to heat/cooling cycles.
You may want to change the design so there's a slight reduction in diameter between the bearing surfaces to make bearing installation easier.
Diy 4th axis rotary table using 100mm chuck with minimal backlash
By kingcreaky in forum Linear & Rotary MotionReplies: 3Last Post: 05-09-2013, 01:03 PM -
shaft - grinding part joint
By dsc in forum Linear & Rotary MotionReplies: 9Last Post: 21-11-2012, 09:31 AM -
Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
By LoveLearn in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 08-02-2012, 01:52 AM -
correcting mill spindle runout
By cocoa_cnc in forum Spindles & Drive MotorsReplies: 4Last Post: 18-01-2009, 06:43 PM -
Measuring Spindle Runout
By Lee Roberts in forum Spindles & Drive MotorsReplies: 0Last Post: 18-10-2008, 11:47 PM
